Need Help with Lexus LS460 TPMS Code C2151
Old Jul 29, 2025 | 03:12 AM
Ben322's Avatar
Ben322
6th Gear
Default Need Help with Lexus LS460 TPMS Code C2151
Hi everyone,
I'm looking for some help with my 2014 Lexus LS460. I'm getting the trouble code C2151: "Circuit of Front Initiator is Open". From what I understand, it's likely a wiring issue, but I'm having trouble locating the front initiator itself.
I've searched for a TPMS wiring diagram specific to the 2014 LS460 but haven’t had any luck. I even removed the left front wheel liner hoping to find the connector (as seen in other Lexus models), but there was nothing there—it seems this model is different.
If anyone has experience with this or access to a wiring diagram, I’d really appreciate your guidance.
Thanks in advance!
Old Aug 2, 2025 | 04:23 PM
tammap's Avatar
tammap
Here you go. Best of luck!
Old Aug 2, 2025 | 05:36 PM
Gerf's Avatar
Gerf
Old Aug 3, 2025 | 07:40 AM
Ben322's Avatar
Ben322
6th Gear
Thank you very much for the valuable information. This is gold as not available anywhere.
one more question, there’s only initiator on the right side?. Left side has no initiator?
Old Aug 3, 2025 | 07:44 AM
Ben322's Avatar
Ben322
6th Gear
Thank you very much for the valuable information. This is gold as it's not available anywhere.
one more question, there’s only one initiator on the right side?. Left side has no initiator?
Old Aug 3, 2025 | 08:46 AM
tammap's Avatar
tammap
Only right side for both front and rear.
Old Aug 3, 2025 | 08:57 AM
Ben322's Avatar
Ben322
6th Gear
Thank you very much for the information. I removed the right-side liner and found a dangling cable with two wires, so I’m guessing the sensor is missing. I’ll need to order one along with the connector and reinstall it. While checking the part number (8976B-50011), I got confused about whether there are two initiators as shown in the diagram. I also checked the left wheel liner but couldn’t find anything there, so you’re right—it’s only on the right side. I’ll go ahead and order the part, install it, and hopefully that will fix the issue.
Old Aug 3, 2025 | 07:44 PM
lexo98's Avatar
lexo98
Any idea how it went missing?
Old Aug 3, 2025 | 08:30 PM
Ben322's Avatar
Ben322
6th Gear
I actually bought this vehicle from US auction, so I have no clue how it got missing. But at least found out where the issue is.
Old Aug 12, 2025 | 12:29 PM
Ben322's Avatar
Ben322
6th Gear
Talking Issue fixed!
I installed a used sensor after finding out it was missing from the car. Now the tire pressure warning is gone, and all four tires are showing pressure readings.
Thanks a million for the documents and the guide. Cheers!
VAM1
Dec 3, 2022 09:43 PM
j32341
Mar 16, 2020 03:55 PM
sajawalas
Sep 9, 2018 10:50 AM
jasone36
Mar 4, 2016 10:50 AM
99navette
Dec 12, 2009 06:56 PM
