Trunk Latch stuck
Old Jul 5, 2025 | 06:52 AM
Hefe's Avatar
Hefe
6th Gear
Default Trunk Latch stuck
I have a question on my 2007 LS 460. My trunk latch is stuck in the closed position after we opened up the trunk to put groceries in it. Now my trunk is stuck open and cannot close it since the latch is stuck in the closed position. Any ideas what I can do I’ve already tried the manual key. I’ve done the interior release as well. However, the latch will not open up thanks for any advice.
Old Jul 6, 2025 | 11:59 AM
trehnhazelwoodls460's Avatar
trehnhazelwoodls460
It's gonna take 2 people to do this. Have 1 person at the trunk unlock button on standby. Open the trunk & put a screwdriver in the whole (lock) where the trunk would be latched. Have someone push the trunk button & simultaneously pull downward with the screwdriver. Sometimes it will work by holding down trunk button on the key fob while doing the process. Pulling downward should allow the locking mechanism to slide to the unlocked position. Let me know if this works. Good luck.
Old Jul 10, 2025 | 04:31 AM
Hefe's Avatar
Hefe
6th Gear
Thanks however did not work.
Old Jul 11, 2025 | 02:15 PM
TheReal1's Avatar
TheReal1
10th Gear
Default Replace the latch
You're going to have to replace the latch assembly. This is who I got mine from. Really easy to work with. https://ebay.us/m/iEBBmC
KennyDaBlack
Mar 10, 2025 11:39 AM
Tratrious
Dec 18, 2024 04:40 PM
Edgar607
Jan 23, 2021 09:32 AM
nmumford
Mar 10, 2019 04:27 PM
Dr C
May 16, 2006 10:26 AM
