Misfire help!
Old Mar 15, 2025 | 05:23 PM
Tberg725's Avatar
Tberg725
2nd gear
Default Misfire help!
I have a 2010 LS460 about 2 weeks ago I was driving home from work (about a 10 minute trip) and boom check engine light is flashing and traction control light comes on so I pull over and have my buddy scan it (Cylinder 8 misfire) pop the coil pig tail off and no change in idle so that confirmed it! And when reconnecting the pigtail the misfire goes away until I made it home then both lights came on with this occurrence I decided I would replace the ignition coil and the spark plug.
For the parts I went directly to the dealership (new coil & plug) after replacing the coil and plug I drove around for about 15 minutes and everything was great until…… the 2 lights come back so to rule out a crap coil from the dealership the new coil on cylinder 8 was swapped for the coil on cylinder 6 and then the test drive goes for about 10-15 and the light is back and car returns to driving like crap
Has anyone here heard of this issue or had a similar problem??
Old Mar 16, 2025 | 06:12 AM
Anfanger's Avatar
Anfanger
What error codes do you get?
Old Mar 16, 2025 | 07:11 AM
Tberg725's Avatar
Tberg725
2nd gear
Dont have the exact codes there was 2 of them, it was Cylinder 8 misfire and a rough idle code
Old Mar 16, 2025 | 07:28 AM
Anfanger's Avatar
Anfanger
There are too many unknowns without errors codes.
Old Mar 16, 2025 | 07:42 AM
Les7311's Avatar
Les7311
Most likely you have a valve cover leak down on the plugs.
did you noticed any oil in the old plugs?
ACP84
NX - 1st Gen (2015-2021)
33
Jul 2, 2025 01:31 PM
ChemEng
Feb 11, 2024 08:39 PM
jcbikes
Jun 22, 2021 11:21 AM
famous187
Feb 23, 2017 07:20 PM
mikemacch
RX - 1st Gen (1999-2003)
Jun 7, 2010 12:51 PM
