Vsc
Old Feb 10, 2025 | 07:47 AM
trehnhazelwoodls460's Avatar
trehnhazelwoodls460
Default Vsc
Has anyone tried this VSC hack?
https://youtu.be/03XK85qwu0Y?si=6zpM6htX6M7bWwZb
Old Feb 10, 2025 | 03:50 PM
2007ls2024's Avatar
2007ls2024
10th Gear
I had the same problem when I put on winter tires. I saw the same vid but opted against messing with the OB2 outlet, bought a cheap scanner, turned the steering wheel straight cleared the code. All fixed and less risk imo.
Old Feb 10, 2025 | 10:07 PM
trehnhazelwoodls460
That's cool but i'm not getting any trouble code. The VSC & Traction Off lights are on. My key fob doesn't work either. I have to touch the push button start with the fob to start the car. Can't lock & unlock the doors. I'm truly trying not to go to the dealership. Nobody seems to have any idea what's goin on.
Old Feb 12, 2025 | 12:52 PM
2007ls2024's Avatar
2007ls2024
10th Gear
I don't remember the exact thread, but someone else had the VSC/Trac light on the dash after exhausting other avenues - it turned out to be two bad cells in his battery. That might explain the key fob not working as well (as I'm sure you've probably replaced the fob battery by now)
Old Feb 13, 2025 | 05:46 AM
trehnhazelwoodls460
I've replaced the battery in the key fob & just bought a new battery. The battery is 4 days old.
Old Feb 13, 2025 | 06:14 AM
Gerf's Avatar
Gerf
If you've double checked that the fob battery is installed correctly and your scan tool is capable of reading proprietary codes this link might help you, water entry in the trunk is kinda common and causes a few issues. I'm assuming when you get close to your car the led doesn't begin to flash?
https://www.clublexus.com/forums/ls-...-location.html
This pdf gives you a better look at the location of the module.
File Type: pdf
WEBEMN
GX - 1st Gen (2003-2009)
Mar 6, 2024 02:56 AM
bbmach
Apr 14, 2023 12:57 PM
scotchbro
Jan 24, 2015 12:11 PM
phenomic
Sep 21, 2010 03:06 PM
