C1289, C1391, C13AF, U0123, U0124 Codes
Old Nov 12, 2024 | 06:04 PM
Anfanger's Avatar
Anfanger
I don't understand how failed ABS pump/actuator would cause U0123 and U0124. I would try to figure out U-errors first, then reset the codes, calibrate ABS and see what happens.
If you messed with wiring, go back and check your work.
Old Nov 13, 2024 | 06:59 AM
derreckla's Avatar
derreckla
Thanks, going to pick up car from shop to do this. Why is my breaks having issues then, locking up....when I do hit break pedal it takes longer then the car stops abruplty, makes a clunking sounds when I let off car and it kind of jumps...
Old Nov 13, 2024 | 03:01 PM
Anfanger's Avatar
Anfanger
There is still a chance you have a failed ABS component but you also have communication errors which are not related to ABS. However, a lot of codes would set ABS code as well but I don't know if ABS codes triggered by other codes would have any changes to ABS behavior as result.
Old Nov 13, 2024 | 05:56 PM
derreckla's Avatar
derreckla
Thanks will most likely get car on friday and after weekend will figure some stuff out will update posting. Thanks for your help
Old Nov 15, 2024 | 01:57 PM
derreckla's Avatar
derreckla
Got it back from Mechanic, all the codes are cleared except C1368, C1345.
Here his notes
"After further inspection notice fluid leaking at the back of the brake booster motor assembly, and loss of pressure at the brake actuator assembly. Recommend to replace both units to complete proper functioning operation"
I looked and there is frest break fluid or oil at the bottom bracket that the brake actuator sits on.
I tried clearing codes and running Linear Valve offset ...ran through test but then the lights didn't flash telling me it was complete.
Any suggestions? is it time to replace the whole break control...
Old Nov 15, 2024 | 04:58 PM
Anfanger's Avatar
Anfanger
It does seem that way sadly.
Old Nov 16, 2024 | 09:30 AM
derreckla's Avatar
derreckla
it appears as i was i was replacing carpet i disconnected one of the sensors thst kicked off U-codes. didnt notice because it didnt come out it was just a bad connection.
this cost me $900 in diagnostic time. this was unrelated to break actuator issue
Old Nov 23, 2024 | 03:19 PM
derreckla's Avatar
derreckla
I replaced Brake Buster and brake Actuator (salvage yard parts to experiment). Watched Youtube video of guy replacing these and was able to have my wife pump the brakes as I bled the air out of the lines and tightened down the lines on actuator.
When I went to clear codes to run solenoid offset I got a new code
C1203 ECM Communication Circuit. It won't clear. My brake pedal now goes all the way to the floor with no resistance.
C1247 stroke sensor code as well. Found youtube video on checking voltage on Stroke sensor on Prius
Sensor 1 - .8 volts
sensor 2 - 4.2 volts
I ran Techstream active test and both of my stroke sensors are at .01 volts.
Connection to the stroke sensor on brake pedal seems connected. Where is the other stroke sensor located?
Any ideas?
Thanks for your help.
SOLVED !!! I LEFT ONE OF THE PLUGS UNPLUGGED AND GOT MORE CODES, PLUGGED IT IN AND CLEARED CODES
Old Nov 27, 2024 | 04:32 PM
derreckla's Avatar
derreckla
SOLVED
I left one of the plugs unplugged and got more codes.
SOLVED!!!
I replaced BRAKE ACtuator and Brake Booster, cleared codes then ran techstream brake bleeding process.
We are good to go haven't taken it for a drive yet but will in next couple days.
Old Dec 2, 2024 | 01:52 PM
derreckla's Avatar
derreckla
Now my turn signals as well as my SRS Airbag light is on too, you have any suggestions?
Using Techstream and manual to check this tomorrow....
Old Dec 3, 2024 | 01:36 PM
derreckla's Avatar
derreckla
When I ran techstream I got a bunch of codes
AFS B2412, B2413 B2417 B2418
SRS Airbag B1660, b1821 - seems that something is loose on passenger seat airbag system
Pre collision - b2090
Electric Power Control - U1111
Pre-collision 2 C1a40, U0123
Any suggestions where I shall start?
Thanks for your time
Old Dec 3, 2024 | 02:47 PM
Gerf's Avatar
Gerf
Just re read the complete thread, if you didn't have this problem before you took the carpets and panels out I would just start all over and take it all out again to go over every connector and harness very carefully for bad connections or pinched harnesses etc. You already said you found one connector already that wasn't plugged back in.
If you had this problem previous to the carpet project disregard this, just trying to help.
Old Dec 3, 2024 | 04:07 PM
derreckla's Avatar
derreckla
Thanks for your reply....
One of the SRS codes tipped me off to the passenger seat, I found a plug that was not plugged in all the way...that cleared ALL THE CODES
My horn nor turn signlas are still NOT WORKING.
My horn has been intermitted since I bought a month ago, the turn signals not working are new.
Does anyone know if this turn signal problem might be the same connection problem the horn has has on steering wheel? On one of my other cars I had to take off airbag and make sure connection was good.
Thanks everyone for your help.
Derreck
Old Jan 12, 2026 | 04:18 AM
Yodog's Avatar
Yodog
So your brake pedal no longer just sinks to the floor?
I assume you got fresh brake fluid with it all?
what’s this techstream brake changing procedure thing in techstream? Is it just providing some critical real time info or is it something that’s required for something related to the brakes?
Rishabh1
Apr 27, 2023 10:35 AM
mochipanda
Mar 11, 2023 02:59 PM
LexStylez
Feb 12, 2019 05:51 PM
dmartine62
Maintenance
Nov 15, 2013 08:40 AM
Curry
Apr 6, 2009 02:11 PM
