Intermittent Left Headlight
Old Oct 20, 2024 | 06:01 AM
OWJ001's Avatar
OWJ001
1st Gear
Default Intermittent Left Headlight
My driver side headlight goes out after being on for a few minutes. If I cycle it off and back on it will work again for a little while (about 7-15 minutes) then go out again. I then repeat. Is this an electrical issue or a bulb about to fail issue?
Old Oct 20, 2024 | 07:12 AM
Anfanger's Avatar
Anfanger
Test the power at the bulb when it goes out.
Old Oct 20, 2024 | 09:04 AM
Gerf's Avatar
Gerf
If you're going to check the voltage at the bulb you might as well replace it, make sure you disconnect the battery before you start taking the front of the inner fender liner down if you're doing this by yourself because the ballast is high voltage. If you have led headlights you need a new assembly.
Old Oct 20, 2024 | 09:23 AM
If HID how old are your bulbs? They don't last forever and what you are describing could be lack of salt
Old Oct 20, 2024 | 09:38 AM
RadiantX45's Avatar
RadiantX45
That’s what happens when an HID bulb is dying.
Old Oct 20, 2024 | 12:47 PM
napamikey's Avatar
napamikey
Yup. I had mine die after a few minutes recently. Replaced with cheapo bulb from Amazon and flickers for about 5 minutes then fine. Got what I paid for.
jshinoski
Maintenance
Dec 24, 2021 05:16 AM
gs4bkny
Jun 26, 2015 08:28 PM
dtaylor
Jan 2, 2012 12:13 PM
DroppedLex
Lighting
Dec 27, 2002 02:36 AM
