2017 LS 460 Yellow Exclamation Mark
Old Aug 21, 2024 | 08:26 AM
htxlexus60's Avatar
htxlexus60
2nd gear
Default 2017 LS 460 Yellow Exclamation Mark
I'm looking to buy a 2017 LS 460. Test drove one at a Toyota dealer & a yellow exclamation point warning light displayed on the dashboard throughout the 15 minute test drive. Salesman tried to tell me that the key fob needed a new battery (I don't agree with that statement). I currently own a 2017 RX 350 Fsport & a 2017 RX 450H Fsport and owned a GS 350 Fsport in the past & have never seen a yellow exclamation indicating a new fob battery needed.
There is lots of information out there on yellow exclamation points, but it's usually with another icon such as a horseshoe indicating low tire pressure.
Does anyone have experience with a yellow exclamation point on its own on a LS 460?
Thanks for any advice!
Old Aug 21, 2024 | 09:49 AM
lili43's Avatar
lili43
If it were keyfob battery… they’d replace that $3 part. Should say in message center. If not, scan tool should reveal it.
Common is also low tire pressure. Also will show in message center.
Finally could just be a simple maintenance due which pops up every 5k.
Old Aug 21, 2024 | 11:25 AM
jmcraney's Avatar
jmcraney
I think maybe the salesman is gaslighting you.
Here are some clips from the 2017 LS460 Owner's Manual:
Old Aug 21, 2024 | 11:58 AM
Marc780's Avatar
Marc780
A yellow light might be any number of things, of course, so I won't even take a guess at it, since your mechanic (for the PPI inspection) ought to do that as part of the inspection. If you are serious about buying this car, and the light is the only issue keeping you from making the decision to buy it, all the more reason to pay a mechanic the $50 or $100 to inspect it.
Old Aug 21, 2024 | 12:30 PM
Nospinzone's Avatar
Nospinzone
[QUOTE=htxlexus60;11775551 Salesman tried to tell me that the key fob needed a new battery (I don't agree with that statement).
Thanks for any advice![/QUOTE]
I agree as well, complete BS. Fine, tell him once he changes the battery and the light is out you will be back.
Old Aug 21, 2024 | 12:50 PM
Gerf's Avatar
Gerf
The yellow exclamation mark inside a triangle is a general warning usually accompanied by a message on the dash like... sunroof is open...key cannot be detected, if your key is covered by your cell phone etc but usually will only stay on for a few seconds then disappear.
If the light stayed on during your entire test drive there should have been a message on the display, if not then probably best not to go any further until you know what it is/was and don't be satisfied if they tell you it was fixed without a good explanation.
Old Aug 21, 2024 | 04:09 PM
htxlexus60's Avatar
htxlexus60
2nd gear
Thank you for responses! I will update again should I purchase the vehicle.
Old Aug 21, 2024 | 05:23 PM
Protholl's Avatar
Protholl
A decent Toyota dealer/mechanic can diagnose this and come up with the codes and possible solutions. I'm thinking the dealer isn't in your corner but trying to misrepresent the car. Be careful and ask if you can have it looked at by a Lexus dealer for a PPI.
Old Aug 21, 2024 | 05:57 PM
swfla's Avatar
swfla
Always get a repurchase inspection from a shop that knows Japanese cars. Used cars are sold as is, even a dealer may sell you a problem car.
Old Aug 21, 2024 | 07:09 PM
DJWLDW's Avatar
DJWLDW
Could be the AC filter needs to be replaced although a message should come up in the message center. Or maybe the AC filter needs to be reset. On my 2010 LS460L you just hold the AC/Climate Off button 4 seconds with the engine off but in the start position.
Dennis
ehc0720
Mar 25, 2016 03:03 PM
LexFather
Oct 29, 2013 10:08 AM
Dbcooper13
Nov 12, 2012 11:08 PM
ikeb
Jul 26, 2012 05:12 PM
junjdm
Jul 23, 2009 07:35 AM
