Transfer Case/Front diff fluid change?
Old Aug 11, 2024 | 08:25 AM
lili43's Avatar
lili43
Default Transfer Case/Front diff fluid change?
LS460 AWD, what is the interval to change this fluid? I can't find it in the user manual and can't seem to find answer, only to "inspect". I've done the rear-diff fluid change.
Old Aug 11, 2024 | 06:54 PM
Anfanger's Avatar
Anfanger
I would do 60k miles change interval. Make sure to use OEM or high quality aftermarket fluids.
Old Aug 11, 2024 | 07:11 PM
Gerf's Avatar
Gerf
What are you planning to use for your transfer case?
Old Aug 11, 2024 | 08:06 PM
Oro's Avatar
Oro
This is a very reasonable interval. 40k to 60k is the general “conventional wisdom,” 40k side for harder-use situations/vehicles and 60k for milder use vehicles. Should last forever with that. I use LubeGard gear oil supplement (2oz/qt) in my diffs now. Great success w/that in a 4x4 rear diff so now using it in all (it’s cheap enough to do so).
Old Aug 11, 2024 | 09:38 PM
lili43's Avatar
lili43
I went to a shop to have some fluids replaced, including rear diff. I did not mention front diff/transfer case. Is it normal and expected to have both done at same time? Paper work doesn’t mention front was completed. I didn’t know there was a front one! I can ask them tomorrow, but as a woman, I’m a little embarrassed by it.
Old Aug 12, 2024 | 05:48 PM
Anfanger's Avatar
Anfanger
Front differential gets neglected for some reason.
Old Aug 13, 2024 | 06:34 AM
weaponoffreedom's Avatar
weaponoffreedom
1st Gear
So the tcase uses regular gl5 gear oil?
Old Aug 13, 2024 | 01:31 PM
Anfanger's Avatar
Anfanger
Transfer case and differential oils requirements are in your owner's manual.
ljCharlie
LX - 3rd Gen (2008-2021)
Sep 16, 2022 09:33 PM
aucht
Hybrid Technology
Aug 9, 2021 04:05 PM
GS4_Fiend
Performance
Mar 28, 2009 09:30 AM
400 Degrez
Performance
Jan 12, 2007 11:01 PM
kennylexsc
Performance
Apr 6, 2006 01:44 PM
