View Poll Results: Did your valley plate leak
600
0%
2012
0%
2016
0%
2017
0%
It leaked again after repair
0%
Multiple Choice Poll. Voters: 4. You may not vote on this poll
Valley plate leak poll
Stricker223
why did you select multiple years? You are skewing the results. Please correct this
unless perhaps you are a mechanic and have repaired those years. If that’s the case that’s fine.
Correct, I've repaired those years. Simply put this is one of those problems you will see over time and miles, it's worse if you don't change coolant or let something in the cooling system have a problem.
https://www.clublexus.com/forums/ls-...-vs-ls460.html
These have been leaking for awhile, car forums seem to make the problem bigger than it actually is. I saw it on a Camry once.
https://www.siennachat.com/threads/2...-reseal.74690/
Being that those are still all UR engines you should considering adding them, especially the ISF/GSF/LC engines as they are also car installed and feature the same DI and VVTi-E systems the LS 1UR does.
Also I don’t see an option to edit the poll to include those models.
https://www.clublexus.com/forums/faq..._rule_new_post
If a moderator closes a thread (for any reason) or asks that you exit a thread, members should not create a new thread to continue the recent discussion
