Lexus ls600hl transmission shifting problem
Old Feb 14, 2024 | 01:30 AM
alimeerry's Avatar
alimeerry
5th Gear
Post Lexus ls600hl transmission shifting problem
What is happening to my car? I got my transmission fluid changed and now when I hit 70-80mph then let off the gas and then hit the pedal hard the car jerks like it’s struggling to move the car again.
Old Feb 14, 2024 | 05:41 AM
swfla's Avatar
swfla
It sounds like the shop that did the fluid change didn’t do it correctly. Lexus requires proprietary procedures and software to do it correctly.
Old Feb 22, 2024 | 03:01 AM
alimeerry's Avatar
alimeerry
5th Gear
Now what is the solution? machine saying you have to change the whole gear box.
Old Feb 22, 2024 | 06:41 AM
evansj's Avatar
evansj
Note that there is nothing to shift in the hybrid transmission of the LS600h. There are no clutch plates or valves. All of the gears are meshed all of the time. There's basically a bunch of gears and two electric motors / generators.
There is a 6 page procedure for changing the oil though, but it boils down to making sure the oil temperature is correct, then making sure it's circulating through the oil cooler, then checking that the level is correct.
Old Feb 23, 2024 | 01:47 PM
Tdes395's Avatar
Tdes395
why did you change the fluid? Lexus says to leave it alone so why not follow Lexus’s instructions
sorry wrong person
Old Feb 23, 2024 | 02:03 PM
Tdes395's Avatar
Tdes395
Old Feb 24, 2024 | 12:20 AM
alimeerry's Avatar
alimeerry
5th Gear
sorry, bro i have no idea about the transmission fluid changing oil. it was my first time experience.
Old Feb 25, 2024 | 12:46 PM
Tdes395's Avatar
Tdes395
oh ok. So what made you decide to get the fluid changed?
Old Feb 25, 2024 | 09:27 PM
alimeerry's Avatar
alimeerry
5th Gear
ya, i decided to change the fluid oil again in proper way with lexus professional machine then let's see. hope for the best (Crossed fingers)
Old Feb 26, 2024 | 11:38 AM
Tdes395's Avatar
Tdes395
I see. So it wasn’t giving you problems. You just decided to change it thinking it was a good preventative measure. In the future it’s best to just follow the owners manual.
Old Feb 29, 2024 | 11:15 AM
JohnnyC407's Avatar
JohnnyC407
Changing it will not cause any issues if you change it according to Toyota/Lexus procedures. 100,000 is when to start checking. All oil breaks down so I have the dealer change all of mine. No issues, ever.
Old Mar 2, 2024 | 09:48 AM
alimeerry's Avatar
alimeerry
5th Gear
Finally, my car has been fixed I just checked the gear oil level again which is 1.5L was extra in it. machine removed it now my car working perfectly. thank you so much guys for helping me out. especially thanks to @evansj
iron
Jun 17, 2014 05:27 AM
chrisoberg
GX - 1st Gen (2003-2009)
Nov 11, 2011 05:40 PM
jaisonline
Sep 18, 2002 08:19 PM
