Help with Codes
Old Jan 9, 2024 | 09:06 AM
Mrcoach's Avatar
Mrcoach
Default Help with Codes
Hello all Happy New Year my 2007 LS460L has been a dream car I’m the second owner had it since 2010. I have 110k miles and never had any issues and 3 weeks ago the Check VSC and PCS lights came on so my mechanic said it was POI38 + P0158 and they Removed and replaced Bank 1 and 2 sensors. It was fine for a few weeks I drove to Florida from NJ Drove about 1 thousand miles and now PO 430 came on saying Catalyst system Efficiency Below Threshold Bank 2. So I was able to clear the code with my reader but have to make the trip back to NJ and wondering if the knowledge that this forum possesses might have some insight into what’s happening and is it safe to drive. I already spent over 1thousand dollars on the sensors I had replaced in NJ. Thanks in advance for your help
Old Jan 9, 2024 | 01:59 PM
Anfanger's Avatar
Anfanger
I am not a mechanic, but if your car takes oil, it might explain issues you have.
Old Jan 9, 2024 | 03:46 PM
swfla's Avatar
swfla
Good suggestion, check oil and coolant. If either is getting into cylinders, lots of potential issues. The valley coolant leak as well as piston rings can happen to a Lexus as old as yours.
Old Jan 9, 2024 | 04:16 PM
Gerf's Avatar
Gerf
Does your car ever sound like it has an exhaust leak?
Old Jan 9, 2024 | 04:56 PM
Mrcoach's Avatar
Mrcoach
So you’re saying my oil or coolant could be low? I just had a synthetic oil change and service before I left for Florida. I will double check it
Old Jan 9, 2024 | 04:59 PM
Mrcoach's Avatar
Mrcoach
No it doesn’t actually it’s smooth and quiet. I thought maybe my Cat is falling.
Old Jan 14, 2024 | 06:18 AM
Biyiklik's Avatar
Biyiklik
Default Help with hvac codes for 2008 ls460
Hi, I have searched a lot online but cannot find the codes numbers after 40ies. I have a driver side not blowing hot air.Ac is working fine for both sides.So when i did pressing ac and recirculate button i am getting these codes
21,24,28,86,87,95
can someone please help me with these codes? I think i have to change either servo or actuator but confused.
Thank you
BigSaveDave
RX - 3rd Gen (2010-2015)
Jul 5, 2023 04:05 AM
LexStylez
Feb 12, 2019 05:51 PM
andcompany
Jan 4, 2019 10:02 AM
ogee4life
Oct 28, 2016 06:24 AM
rbrtclk
May 10, 2010 01:25 PM
