Outer Tie Rod removal problems
Old Dec 11, 2023 | 07:43 AM
taketheLS460's Avatar
taketheLS460
3rd Gear
Default Outer Tie Rod removal problems
2009 LEXUS LS460 AWD DRIVER FRONT
Long shot but while removing my outer tie rod….the metal insert that is in the knuckle came out too. Unfortunately, Lexus does not sell this part separately from the knuckle.
The metal insert will not budge. Tried using a hammer and fork, torched it, a manual press, all the pb blaster and this. But it probably only moved a cm.
Has anyone else ran into this problem removing the outer tie rod?
I am taking it to a shop to see if they can press it out but I’m wondering if anyone has any advice :’)
It broke my press too LOL
Outer tie rod in the insert that is in the knuckle
Reference of location of insert
Old Dec 11, 2023 | 08:25 AM
JohnnyC407's Avatar
JohnnyC407
You could try a 3 prong press. Or put in a vice and beat the end of the tie rod?
Old Dec 11, 2023 | 11:56 AM
swfla's Avatar
swfla
There are several threads about this issue already. Try a search for lots of instant info.
Old Dec 11, 2023 | 12:39 PM
taketheLS460
3rd Gear
Old Dec 11, 2023 | 12:47 PM
Cut the ball joint off at the bottom then you can easily support the bushing and press the stud out. You will need a hydraulic press for this.
Old Dec 12, 2023 | 08:03 AM
taketheLS460
3rd Gear
Luckily the knuckle insert was saved!
Big O Tire was able to press it out without causing any damage to it.
Thanks everyone!
HtownBlue
Sep 18, 2022 07:26 AM
Oro
May 22, 2021 03:34 PM
westopill
16
Apr 22, 2019 11:24 AM
BradTank
Dec 17, 2015 09:42 AM
