Keys not working
Old Aug 15, 2023 | 12:39 PM
Zetascry's Avatar
Zetascry
Originally Posted by Gerf
Were you on this page in TS? it should tell you what is wrong or get you real close.
yes- am I looking to see if immobilizer is set/unset?
Old Aug 15, 2023 | 12:42 PM
Gerf's Avatar
Gerf
Well, everything is functional in my car so if you see something different that could be the issue. How does it compare?
Mine was ignition on engine off with drivers door open.
Old Aug 15, 2023 | 01:08 PM
swfla's Avatar
swfla
Great post Gerf. You had your thinking cap on today!! This is probably the most helpful thing a forum member can do.
Old Aug 15, 2023 | 01:26 PM
Zetascry's Avatar
Zetascry
This is what I See
Old Aug 15, 2023 | 01:45 PM
Gerf's Avatar
Gerf
You have a trouble code, go back one page a see what it is.
Old Aug 15, 2023 | 01:48 PM
Zetascry's Avatar
Zetascry
yes I tried remote engine start test, which I reset because my vehicle doesn’t have the option..I’m going to the store and trying another new battery..btw I think the remote just fell “asleep” if that’s a thing from doing research and seeing other brands face this issue..I’ve had this issue with my Toyota key which battery died but when replaced the car wouldn’t start until I did a “reprogram” procedure
Old Aug 15, 2023 | 01:53 PM
Gerf's Avatar
Gerf
So you're saying you knew about this code and never thought to mention it? What was the code?
Old Aug 15, 2023 | 01:56 PM
Zetascry's Avatar
Zetascry
This code only came up when I tried to do a test from the utilities tab- it was a failed remote start test . I tried this prior to taking photo of active data. Honestly just tried everything in techstream to find the issue
Old Aug 15, 2023 | 02:05 PM
Gerf's Avatar
Gerf
Okiedokie.....
Old Aug 15, 2023 | 02:07 PM
Zetascry's Avatar
Zetascry
Okiedokie.....
everything that I know haha 😂 this sucks
Old Aug 15, 2023 | 04:14 PM
Zetascry's Avatar
Zetascry
Changed battery with new energizer one- still the same issue.
Old Aug 15, 2023 | 05:09 PM
jmcraney's Avatar
jmcraney
The Smart Access System can be turned off through the Customizable Features. You should check to see if it is turned off. It is accessible through the controls on the dash. You want it ON.
Old Aug 15, 2023 | 08:23 PM
Zetascry's Avatar
Zetascry
entry by smart key in dash settings is turned on, hope that’s the same thing
Old Aug 15, 2023 | 10:44 PM
jmcraney's Avatar
jmcraney
Do you have an Owner’s Manual? One comes with every new car.
Old Aug 15, 2023 | 10:54 PM
Zetascry's Avatar
Zetascry
yes-turned to you guys first in hope of a quick fix
