screen problem
Old Jun 30, 2023 | 01:36 PM
suzi2008uk's Avatar
suzi2008uk
7th Gear
Default screen problem
hello not sure if anyone else has this problem while using screen checked fuses seem ok and amp ok but no sound only when you use voice commands.
what happens when you press maintenance other icon work
radio no sound
sound options but no sound
info menu
when you press map
when you press disp
menu button
when you press goes blank
Old Jun 30, 2023 | 01:59 PM
swfla's Avatar
swfla
Pre 2013? The unit needs to come out. There are multiple companies that do repairs, yours will need it. United Radio is one mentioned here often. Used is an option but it could die, repair is best bet.
Old Jun 30, 2023 | 02:54 PM
Sherl's Avatar
Sherl
If it's display then used part on ebay is like $200-400 and you can DIY screen replacement. Just google Grom audio vline install and they have a demo where they pull this screen out. It's simple
Old Jul 1, 2023 | 06:47 PM
suzi2008uk's Avatar
suzi2008uk
7th Gear
Default vline or android
If i get vline or android head unit would this solve the problem or do i need to get it repair.
thanks
Old Jul 1, 2023 | 06:55 PM
swfla's Avatar
swfla
If you can find a unit with a screen that works with Lexus. That's the challenge.
Old Jul 13, 2023 | 09:49 AM
suzi2008uk's Avatar
suzi2008uk
7th Gear
Default update ls 600hl 2007
well i have changed the screen and radio and cd player and still screen problem and no sound
but once unplugged a cable shown on picture sound now work but not whole of screen
i took pics of check menu listed below hope sone can shed some light on this.
port unplugged sound back
lan monitor
unit id
system check
Old Jul 13, 2023 | 12:44 PM
swfla's Avatar
swfla
If you replaced the entire unit, then there may be a wiring issue. I've seen several threads where a wire has gotten nicked or pinched and causes unexplainable issues. Usually this occurs when something has been added to the car's electric system. Even a dash cam direct wired into the car. If a Grom system had been installed, that would be a likely suspect.
Old Jul 13, 2023 | 03:40 PM
rehr0001's Avatar
rehr0001
Agreed - I saw that screen commonly when the Grom crashed. It doesn’t look like there’s anything wrong with the screen as graphics display fine in some instances. Are you sure there is nothing aftermarket installed on your car?
Old Jul 14, 2023 | 05:26 AM
suzi2008uk's Avatar
suzi2008uk
7th Gear
Talking
hi no aftermarkets parts no grom ect try in another ls 600h radio and screen and worked fine its that port making the problems and even changed amp costing me alot now lol
Old Jul 14, 2023 | 07:55 AM
swfla's Avatar
swfla
it's possible the plug or port are bad. As you said, that's when it's a problem. Get a magnifier and carefully examine wires and pins of plug. There are kits for redoing these items. If a repair was done adjacent to the screen or along the route of the wires in the dash. Climate control system is a typical repair that could accidentally damage a wire. I've read it here in the forum. If you're not the original owner, you just don't know who's been into that dash. I've even read about previous owners removing an aftermarket item when selling the car. Leaving damage behind that may not short out right away. Obviously a difficult and time consuming process to examine all wires.
Acrad
GX - 2nd Gen (2010-2023)
59
Mar 20, 2026 08:39 AM
GFerg
Apr 1, 2024 04:35 AM
Hoovey689
Dec 12, 2021 10:53 AM
Margate330
Dec 30, 2020 11:38 PM
picker
RX - 3rd Gen (2010-2015)
Apr 8, 2009 05:37 PM
