Noise reduction improvements
Old May 9, 2023 | 07:59 PM
HushedRide's Avatar
HushedRide
Nice work @FlexnLexus ! Great to hear that you found meaningful results.
Post #13 on this DIYMobileAudio thread details a similar method for wheel well noise control. Will be attempting this later in the month.
Old May 10, 2023 | 03:20 AM
FlexnLexus's Avatar
FlexnLexus
Originally Posted by ausLX
Those pads are going to peel and fall off in no time. Did you consider removing your wheel well liners to stick the sound deadening on the inside.
I did consider it, but then i didn’t want to have any fitment issues from having the pads being too bulky when reinstalling the liner. Plus i believe behind the plastic liner near the front end by the bumper, is open space to get to the headlight bulb, so you can’t install any padding behind the liner only the on the opposite side you possibly could. But then the surface is rough and most likely the pads won’t stick the actual metal portion all too well of the inner body behind the liner.
I had old rubber pads on the plastic liner prior to me installing the new ones, and they never came off even with all the rain we’ve had in CA this past winter. Only time will tell, but I made sure I rubbed down the pads with the roller really well so they don’t come off.
Old May 10, 2023 | 03:22 AM
FlexnLexus's Avatar
FlexnLexus
Thanks brother. let us know how it turns out. 👌👍
rns
Hybrid Technology
13
Mar 31, 2023 07:42 PM
Shaylee
NX - 2nd Gen (2022-current)
16
Feb 1, 2023 10:34 AM
pinoiryder
Feb 7, 2011 09:50 AM
PhilipMSPT
Apr 28, 2009 08:47 PM
nardeezy
Mar 29, 2006 07:32 AM
