Code p1349
Old Jan 11, 2023 | 02:22 AM
alihassanj's Avatar
alihassanj
1st Gear
Default Code p1349
I have code p 1349 I have reset it again it comes back
so I have opened the vvt valve and cleaned it and ohm it
it was with in limit
also I have operated by using wire from the battery it was working OK
i fit it back again i get same code
the engine is working fine
Could it be the cam shaft oil control filter
how to change the oil filter
Old Jan 11, 2023 | 06:40 AM
BigBoomer's Avatar
BigBoomer
https://parts.olathetoyota.com/p1349-code
Old Jan 11, 2023 | 07:54 AM
911LE's Avatar
911LE
That filter is under the big front cam cap. It's just a mesh screen. I've never seen one plugged even with high mileage and poor maintenance. If it is plugged you have much bigger issues.
Kevinsprin
Dec 16, 2017 02:17 PM
lexusisgs
Jun 20, 2017 11:45 PM
mphsatty
Oct 4, 2016 08:26 AM
mildawg
Jan 29, 2014 07:46 PM
