LS 430 cranks over but no start can’t find ECU
Old Nov 26, 2022 | 04:04 PM
timmytimto's Avatar
timmytimto
10th Gear
Default LS 430 cranks over but no start can’t find ECU
Hi guys, first time posting on here. I’ve got an ls430 that will crank over but will not start! I’ve tried to read the codes but the link can’t be established! No communication. It seems when you turn the ignition switch on the cooling fans start and stay going. Any idea what would be causing this?
Old Nov 26, 2022 | 04:15 PM
ExiledWolf84's Avatar
ExiledWolf84
When you turn the key to the "on" position, does the check engine light illuminate while the engine is off? If not, then the ECU is either toast, or simply not getting power.
I would start checking fuses before anything else.
Old Nov 26, 2022 | 04:35 PM
timmytimto's Avatar
timmytimto
10th Gear
Originally Posted by timmytimto;[url=tel:11400008
11400008[/url]]Hi guys, first time posting on here. I’ve got an ls430 that will crank over but will not start! I’ve tried to read the codes but the link can’t be established! No communication. It seems when you turn the ignition switch on the cooling fans start and stay going. Any idea what would be causing this?
Have checked fuses and they all seem fine started checking relays and they seem ok also! Why would the fans be on when it’s completely cold? I’ve changed the temperature sensor and thermostat with new oem. Did not fix it! Any other ideas much appreciated
Old Nov 26, 2022 | 05:08 PM
timmytimto's Avatar
timmytimto
10th Gear
Originally Posted by timmytimto;[url=tel:11400017
11400017[/url]]Have checked fuses and they all seem fine started checking relays and they seem ok also! Why would the fans be on when it’s completely cold? I’ve changed the temperature sensor and thermostat with new oem. Did not fix it! Any other ideas much appreciated
The triangle! Red light comes on is that the check engine light you mentioned?
Old Nov 27, 2022 | 10:49 AM
ExiledWolf84
The red triangle is a fault indicator, and should have a message that is displayed along with it. For example, mine came on the other day because of the washer fluid level was low.
The light I was referring to is the run of the mill orange "check engine" light, that illuminates of a problem is detected, and also lights up when the engine is off.
Old Nov 27, 2022 | 12:28 PM
chuyrobles's Avatar
chuyrobles
A fan switch may be faulty and/or fan relay may be stuck. but that don't explain why the car wont start. Maybe the battery is not strong enough to crank the engine over normally.
Old Nov 27, 2022 | 02:24 PM
lp2k's Avatar
lp2k
try jump starting the car and report back
Old Mar 10, 2025 | 12:12 PM
obyjp's Avatar
obyjp
2nd gear
got the same issue right now, did you ever find out what the problem was?
Old Mar 10, 2025 | 12:25 PM
weldthedif's Avatar
weldthedif
its probably an ECU or Immobilizer issue
Old Mar 10, 2025 | 12:32 PM
alextv's Avatar
alextv
Describe your symptoms. Are you using same key and tried different key and did it happen after starting fine and next time not with no work in between?
Old Mar 10, 2025 | 12:46 PM
obyjp's Avatar
obyjp
2nd gear
have tried different key no difference, scanner has trouble connecting, also did a timing chain replacement
Old Mar 10, 2025 | 01:33 PM
bradland's Avatar
bradland
Timing BELT
Who did the work?
Old Aug 10, 2025 | 08:38 PM
xtr3me's Avatar
xtr3me
Has this fault been corrected?
I had same issue in the past, Corrective action was replacing faulty ING 2 relay
Old Oct 29, 2025 | 11:47 AM
tlylesbey's Avatar
tlylesbey
im having the same issue, no work has been done
What ever is the red is why I believe I’m not getting power
to the vehicle, I’m not getting power to the ig2 relay
Old Oct 29, 2025 | 12:44 PM
alextv's Avatar
alextv
Do you have power at the fusible link both sides? If not it has to be the connection
