Help!!! with Bank1-Sensor 1, O2 sensor terminal
Old Nov 6, 2022 | 11:50 AM
gomboy60's Avatar
gomboy60
Exclamation Help!!! with Bank1-Sensor 1, O2 sensor terminal
Hi all,
A desperate DIYer needs some help. I have 05 LS430 with 70k miles. My aging mom drove till she no longer able to. With P0031 code, I was trying to replace B1S1 sensor (located underneath driver side floor) AND here is the biggest BOOBOO on my part, while trying to disconnect, I inadvertently pull the plastic connector on the vehicle side off the 4 wires!! I know I could only blame myself but now I have a serious issue at my hand. The free wires are way deep inside the tight space and I have no way to get to them. As for the orientation of the wires, I am quite confident that which wires (green, shiny black, dull black and yellow) goes to which 4 terminal on the plastic connecter. Most of you have more experience with cars in general and probably have better ideas than I do. Or maybe if you know someone who can repair this, please let me know. I am in SoCal and the car is mechanically perfect condition with some aesthetic issue like scuff marks. I love how over engineered this vehicle is and love this model more than 2012 LS460 I have.
Thank you and looking forward to hear from anyone with any ideas!!
Old Nov 6, 2022 | 03:22 PM
lp2k's Avatar
lp2k
You posted in the LS430 section so you need to post this in the correct section for help, Most of us only know the LS430 which is a model before the LS460
Old Nov 6, 2022 | 03:32 PM
VolumeToo's Avatar
VolumeToo
I would suggest that way to go is to get a junkyard tail and splice it on. (OK, it'll be a little longer than before but so what?) Obs the pins are crimped on to the wire, so unless you have new pins of the correct type, are willing / able to de-pin the original connector, have the right crimp tool AND enough space to get it in there... (Impossible, basically!)
Best way to splice is solder / heatshrink each wire then wrap overall with self-amalgamating tape for waterproofing.
Set aside a whole day for this and plan it really carefully. Should be OK.
Old Nov 6, 2022 | 05:51 PM
k7q's Avatar
k7q
This happened to me. I had to remove the catalytic converter to get more space to work on it.
paultattoo
Dec 2, 2019 10:03 AM
Billnoelr
Apr 21, 2019 04:37 PM
dta20502
12
Mar 8, 2019 06:37 AM
coug66
Jul 25, 2017 03:52 AM
fpoljanec
Jun 8, 2017 03:07 AM
