DIY Brake flush question
Old Jun 10, 2022 | 12:59 PM
LatinLS430's Avatar
LatinLS430
Default DIY Brake flush question
Several years ago I did a DIY on a pressurised system on my 2013 GS350.
https://www.clublexus.com/forums/gs-...h-for-4gs.html
I want to do the same process and use the same equipment on my 2006 LS 430.
Do you guys think I can do the same process or is there a specific process for our cars?
Old Jun 12, 2022 | 10:35 AM
Romanova's Avatar
Romanova
Process should be identical with the order in which you perform the bleed. Curious to hear if that setup works also.... keep us posted!
Old Jun 13, 2022 | 04:12 AM
nvwls's Avatar
nvwls
I used the Motive bleeder (https://www.ecstuning.com/b-motive-p...eder/motivepb/), which essentially works the same way. Fairly easy and clean to use, nice to not have to ask someone to pump the brakes. I ended up having to purchase an adapter as well, as the one included doesn't fit our brake reservoir. It looks like Speedibleed sells those alone as well.
GS400Star
Aug 1, 2011 01:37 PM
amiehe
Suspension and Brakes
Apr 26, 2011 08:24 PM
JDM _GS3
Feb 26, 2009 01:57 PM
unit74
Oct 18, 2007 10:16 AM
THoon
Aug 3, 2007 05:02 PM
