Hi how do I disable the auto down function on the rear sunshade? Meaning, how do I stop the sun shade from going down when I switch the car into reverse? I want the buttons to be fully functional so I won't pull the fuse .
OK I figured it out. First I removed the third brake light (just kinda slides into place) , then I reached down in there and I managed to grab and disconnect the connector that goes i j to the sunshade motor. Then I removed the second pin to the right and plugged the connector back in, now it works like a charm, stays up when I want it, goes down when I want it
Nice job. I only use it on the highway and when parked outside. I don't like driving over bumpy in-town roads with it extended. Admittedly I am a little paranoid since that thing is expensive and I have heard they are becoming more scarce, heading towards disappearance.
So, it's the right most wire that you disconnected in this picture with the tab facing up?
How did you manage to pull that wire/pin out of the harness? I have the 2004 and need to pull the orange, seems a pain
