Should I also replace bolts & nuts when replacing shocks?
Old Nov 18, 2021 | 10:36 AM
BlakeLS's Avatar
BlakeLS
Default Should I also replace bolts & nuts when replacing shocks?
Planning to replace my front shocks and shock mounts, and want to check with the experts on the following:
Are the bolts & nuts in red reusable or one time use like the caliper bolts? Also am I missing anything else that should be replaced while I'm doing this?
Thanks for your inputs.
Old Nov 18, 2021 | 11:11 AM
You should replace all but the lower arm hardware if I remember correctly. The factory nuts for the strut mounts however are far better than what's provided with any aftermarket mount so between those two I would and did reuse stock.
If you are concerned buy new OE hardware.
Old Nov 18, 2021 | 11:13 AM
Aus430's Avatar
Aus430
I reused mine. The torque settings aren't that high.
The strut should come with a new nut in the box that you can use.
Get genuine strut mounts if replacing, as people here have been unsatisfied with after market ones. I reused mine as they were good enough - no weird noises.
Kyb shocks are good.
ShortyCox
Oct 27, 2019 08:28 PM
Noobierice
Suspension and Brakes
Jun 18, 2019 01:53 PM
BradTank
GX - 1st Gen (2003-2009)
60
Aug 26, 2017 10:09 PM
chrisvr6
Jan 11, 2012 03:40 AM
SoCal_VIP
12
Dec 30, 2006 05:40 PM
