Every where i search i see this amps ohm loads being discussed but not the actual wattage per channel. i believe from my research the total wattage was 240 watts.
does any know the actual output wattage per channel?
im looking into finding speakers from somewhere likes parts express that just fit the specs of the amp which is easily doable if i just know all the specs.
With speakers you need to match the impedance of that output of the amp and the efficiency to the original speaker.
In terms of wattage, so long as the rating of the speaker is above the maximum of the amp, you are good.
As for the specific power per channel, I don't think anybody knows.
If you get speakers rated at over 60W you should be fine.
