LS430 Right Headlight Replacement/Flickering/Going Out
Old Jun 28, 2021 | 11:21 PM
ryanzx750's Avatar
ryanzx750
10th Gear
Lightbulb LS430 Right Headlight Replacement/Flickering/Going Out
The Passsenger (right side) Headlight is flickering and barely shining. Obviously its about to go out. Is this a bulb? The whole assembly is about $1,200. Any ideas, Suggestions, Comments?
How can I tell if it is the balast?
Old Jun 29, 2021 | 03:16 AM
BigBoomer's Avatar
BigBoomer
If it's low beam, most likely the bulb. HID bulbs last a long time, but they don't last forever.
I would replace the bulb first. If it still flickers after that, then you need to replace the ballast.
It could also be a poor earth connection as your high-beam on that side doesn't seem as bright as the other side either and that is a normal halogen bulb.
Old Jun 29, 2021 | 08:18 AM
infojunky's Avatar
infojunky
Swap your bulbs, If issue remains, then it is probably your ballast. Lexus did a poor job on sealing ballasts and you will probably find moister inside. When you have the bulb out you may want to run compressed air inside the headlight to dry out the moister and then seal edges with silicone.
Old Jun 29, 2021 | 01:45 PM
ryanzx750's Avatar
ryanzx750
10th Gear
Thanks. I tried a different bulb and it still had the flicker. What yall are saying makes sense. Looks like moisture not just in the headlight assembly, but also in ballast itself.
I assume the LEXUS OEM Computer Light Control Part is the same thing as a ballast.
Old Jun 30, 2021 | 07:10 AM
infojunky's Avatar
infojunky
https://parts.lexus.com/p/Lexus_2005...596750020.html
Amazon Amazon
roughly $30
I went with an Amazon version. Sorry , I don't recall which one. Still holding up after 3 years. I did seal the edges and any possible water intrusion places with silicone prior to installing.
Old Jun 30, 2021 | 07:19 AM
kos's Avatar
kos
Is that condensation / moisture buildup on the inside of the lens, or the outside?
Old Jun 30, 2021 | 10:59 PM
ryanzx750's Avatar
ryanzx750
10th Gear
The moisture is on the inside...the headlight has a little bit of a gap that lets it in. Also, water comes from behind the headlight from a space missing in the fender well.
Old Jun 30, 2021 | 11:02 PM
ryanzx750's Avatar
ryanzx750
10th Gear
Should I pay the $300 for the computer light control balast from Lexus or try the cheap one from Amazon?
Old Jul 1, 2021 | 12:00 PM
nvwls's Avatar
nvwls
I used the cheap one from Amazon, but make sure to use a good quality sealant like Morimoto butyl rubber (can find on Retrofit Source)
Old Jul 1, 2021 | 03:41 PM
kos's Avatar
kos
Need to fix that leak for sure, that will only cause future headaches with any electronics in the headlight housing.
https://lightwerkz.net/collections/build-materials <---plenty of good accessories in this link from @LightWerkz that can help the issues your having, even some silica gel packs that can absorb moisture inside a housing.
CowBoE
Mar 24, 2021 08:31 PM
humberonia
Dec 13, 2014 09:53 AM
Zinda
Apr 12, 2014 03:24 PM
infa_red
Lighting
Mar 19, 2008 02:23 PM
