CD player plays, but no audio?
The CD clearly is playing based on the screen, but no audio, tape deck works. I even replaced the CD player itself and it did the same thing. I noticed under the passenger floor it looks like the previous owner spliced in some sort of CB radio. Should I go there first or do you guys have any other ideas? Gateway ECU possibly? TIA.
I literally cannot find anyone else whose had this problem. I see lots of no audio at all, or the CD player having a read error, but mine is clearly playing, just no audio. Frustrating! Guess I'll dig into it next weekend.
Could be a fault with the CD player connector.
Is it an ML system? If so, then it's the 6 pin connector in the back of the unit.
Check all the pins are seated correctly and check the wiring.
If it's been played with, then all bets are off.
emg2919
Jan 8, 2014 10:16 AM
