No climate control?
Old Apr 28, 2021 | 08:46 AM
93Phoenix's Avatar
93Phoenix
Default *SOLVED* No climate control?
Hey guys, new member but long time lurker. I've had my 01 LS UL package for over 4 years now. A year ago the Nav went out, and now the climate control only works intermittently, strangely it tends to not work after it rains. I unplugged the nav module and it was pretty rusty. I understand the climate control can work independently from it. Where should I start before I start throwing parts at it? Nav screen unit? Gateway ECU, any other ideas?
Also, if I do in fact need a new screen, amplifier etc, am I better off going aftermarket? Which one do you guys recommend, I've seen a bunch but not sure which one(s) are most popular here.
Thanks,
Andrew
pic unrelated:
Old Apr 28, 2021 | 11:43 AM
wnyjazz's Avatar
wnyjazz
I had the same problem.
Here’s the thread...
https://www.clublexus.com/forums/ls-...nditioner.html
Old Apr 28, 2021 | 11:57 AM
93Phoenix's Avatar
93Phoenix
Thanks. I do believe i saw your thread a bit ago. What did you pay for the used amp? They seem pricey hence wondering if going aftermarket would yield a better end result for the price.
Old Apr 28, 2021 | 12:24 PM
wnyjazz's Avatar
wnyjazz
I wish I remembered how much. I’m thinking $200(?).
I got it on ebay at the end of 2018 I believe, and unfortunately they wipe out records of older purchases. No cool imho.
I didn’t look into aftermarket units.
Old Apr 29, 2021 | 08:42 AM
93Phoenix's Avatar
93Phoenix
So I noticed the amp you installed is a pioneer unit, this means you don't have the Mark Levinson system?
Also, I'm a fellow WNY'er in Rochester. Where are you?
Old May 15, 2021 | 06:38 AM
93Phoenix's Avatar
93Phoenix
Hey man! Thanks for the suggestion, grabbed a used Levinson off of ebay and the climate works flawlessly now. Can bus sure is a strange character! Thanks again!
wnyjazz
Mar 5, 2022 01:22 PM
texsexlex
Feb 7, 2014 01:31 PM
Toptier
May 23, 2007 04:27 PM
