LS430 ECU Tuning
I’ve been lurking around for a few weeks planning my upgrade list as I search the Internet for the right LS430 to buy. Pretty much everything I read says you’ve gotta go stand alone ECU or piggy back but it isn’t very beneficial. Neither are something I’d want to mess with.
Turns out there’s a guy in Moscow named George that can tune the 3UZ in the LS430 on the OEM ECU. It starts on page 2, one guy has received one and is raving about it. Hope he can get it on the dyno to verify some gains.
Maybe this is old news but it’s new to me!
https://www.lextreme.com/forums/inde...e-flash.17541/
I have it as well, going to the track next week t see if it improved the times. I've already observed a full second improvement 0-60 for my car that puts it below factory new spec. Compensates for 215k miles of wear and then some nicely
How long have you had it? Please come back and let me know what the results are.
Thank you for letting us know about remapping service available here in US. Looks like $175 dollars is the decent price for such an upgrade. Will be sending them the ECU in couple of weeks and will submit my feedback.
Instead of the SST, you can simply use a paperclip or wire to connect the two pins. Overall, it's fairly straightforward and you should see all the lights flashing. Another note about installation, be careful removing the 4 screws holding the original ECU, it's very easy to strip the heads on these.
I'm fairly impressed driving with the new ECU. I mostly drive in ECT PWR, and that's when you can notice the most difference. The throttle response is almost instantaneous, it reminds me of Sport mode in newer Lexus vehicles. Gears are definitely held for longer. I opted to have my rev limit increased to 7500, but did not test this out yet. Something odd I noticed was when driving in manual mode, it does not downshift into second gear (nothing happens). I'm not sure if that is normal. After I installed the new ECU, the CEL turned on and I had a DTC for P1765. I had no DTCs prior to installing the new ECU, but maybe this is a coincidence. Everything seems to shift fine except for second gear. I will likely try my original ECU and see if I have the same DTC.
Turnaround time and communication for quantum-auto was fairly good as well. I ordered a new ECU instead of sending mine in, and it took 9 days from order placed to delivered. If I can get that DTC resolved, I can probably take this to the dyno and test it.
Update: Received a replacement ECU from quantum-auto. This fixed all the issues I was having. Everything works well with no DTCs or check engine light, and shifting into second gear works as expected. Good customer support from quantum-auto. Driving with the replacement ECU does seem much smoother than before, even in ECT PWR, overall happy with this ECU. Planning to get this on the dyno soon
