Battery dead again
Old Aug 7, 2020 | 11:27 AM
jmdav89's Avatar
jmdav89
Default Battery dead again
So I try to take the car out for a spin every 3 or 4 days to keep the battery up but today it was dead. I had the battery tested and the alternator is working ok (as of 2 months ago) so I'm wondering what is dragging the battery down. I notice the security light and smart key light are flashing all the time when the car is not running. I pressed the smart key off button to take this out of the picture.
Is the security system being active enough to kill the battery in 3 to 4 days? Any thoughts on another reason for So much drain? Thanks
Old Aug 7, 2020 | 11:37 AM
bradland's Avatar
bradland
Where do you store the Smart Key when the car is parked?
If it's within range the key constantly communicates with the car. Store the key at least 15 to 20 feet away.
Old Aug 8, 2020 | 06:20 AM
jmdav89's Avatar
jmdav89
Bradland, I keep the smart key in the house about 25' away from the garage. BTW just noticed the sticker on the battery it is Now 4 years old.
Old Aug 8, 2020 | 07:15 AM
430SLOwner's Avatar
430SLOwner
There you go....
Old Aug 8, 2020 | 10:18 AM
TominPT's Avatar
TominPT
The big bugaboo for me is not having all the doors completely closed, which causes interior lights to stay on and voi la the battery goes dead. Make sure all doors are closed even after you get a new battery.
Old Aug 8, 2020 | 10:27 AM
jmdav89's Avatar
jmdav89
So I just finished charging the battery then started the car. It turned over like i was starting it on a cold morning in the dead of winter. I put a Volt meter across the battery terminals while running and i get around 14.3 volts so I'm thinking the alternator is working but the battery is ng.
Old Aug 8, 2020 | 01:15 PM
430SLOwner's Avatar
430SLOwner
More than likely....
Old Aug 8, 2020 | 02:36 PM
jmdav89's Avatar
jmdav89
AAA just left. It was the battery. Alternator tested good. Happy ending and thanks for the help.
Old Aug 8, 2020 | 02:51 PM
Johnhav430's Avatar
Johnhav430
Remember HS physics, v = ir. I believe this is why so many complaints with battery tenders, where users say the light was green, yet car cannot start (this is on a bad battery, that is--good battery maintained on a tender of course is going to start the car). Web seems to say the green light means the proper voltage was reached.
On bad batteries, voltage can be OK, but the resistance is high, so no current.
Example....
Old Aug 10, 2020 | 01:36 PM
KO21's Avatar
KO21
TominPT, I used to have a Subaru that when I closed the hatch, I would find out the next day that the car wouldn't start because while the hatch appeared closed, it wasn't thoroughly closed and that rear dome light drew battery. It wasn't a big deal because I would just pull out the jumper box and be on my way. Eventually I just changed the dome switch from "automatic on" to "manual on."
jimisbell
Dec 10, 2018 07:48 PM
lex3gs3198
Maintenance
Apr 4, 2013 07:31 PM
Ducati11
May 22, 2011 04:45 PM
GoldGS3
Dec 15, 2009 06:33 PM
roberttran
12
Jul 29, 2004 04:45 PM
