Error Codes + AFS Flash LS430 2004 after working on the car + installing Datasystem
Old Jul 21, 2020 | 08:10 AM
NLLex's Avatar
NLLex
Question Error Codes + AFS Flash LS430 2004 after working on the car + installing Datasystem
Hello friends,
I have worked on my car for a few months now. I cleaned and changed the brakes front van rear and I really took my time for it, letting the car on jacks. I also installed the android radio and took it out again, changing it for the original and I also pulled the plug of the steering wheel motor for telescoping because it was only tsjirping and not going anywhere. ( Tried a refurbished motor which didnt make it work ) That means that I had to take apart many things like the cover under the steering wheel which contains the ASF button and I installed a factory new Datacontroller but I didnt hook up the device yet. Just installed the cables through the car.
I have build everything back on and the car has still the engine error light + the flashing ASF + error code with hight level + I have 4 faults on all 4 of the 4 air shocks.
Ill try to post the error codes later on.
Hope you guys have an idea what it could be.
Old Jul 22, 2020 | 12:34 PM
NLLex's Avatar
NLLex
I found the solution and this may be helpful for other Datasystem users. If you dont hook up the device after installing the wiring because you are afraid of pushing the wrong buttons (like me) you get all sorts of error codes like the ones above so you really need to put the plug in the little box.
Nicklatif
Jun 6, 2019 01:59 PM
Rotary13b
Feb 2, 2018 11:38 AM
harvfran
Jul 25, 2011 08:02 AM
C Anderson
Aug 10, 2008 01:25 PM
JBrewster
Mar 15, 2008 10:26 PM
