Engine mount torque spec
Old Mar 14, 2020 | 07:18 AM
repairmatt's Avatar
repairmatt
Default Engine mount torque spec
I have a question on the engine mounts. Currently changing them and I just realized that while the torque for the bracket holding the insulator to the engine is easily found (27 ft lb), I cannot find torque specs for the single nuts in the center that hold the insulator to the top and bottom brackets. Can anyone help with this?
Old Mar 14, 2020 | 01:58 PM
rkw77080's Avatar
rkw77080
Please take a look at the link below...
https://www.clublexus.com/forums/ls-...006-ls430.html
Old Mar 14, 2020 | 08:16 PM
repairmatt's Avatar
repairmatt
I did, multiple times before I posted this. There is nothing about the single nuts for the top and bottom bolts that hold the insulator to the brackets. There is the torque specs for the upper and lower brackets and the transmission mount, but nothing about the top and bottom nuts for the insulator.
Old Mar 15, 2020 | 03:35 AM
rkw77080's Avatar
rkw77080
The rubber engine mount is referred to as "engine mounting insulator" in the repair manual. The mounting bolts (to the bracket and to the chassis) should be torqued to 50 ft.lbf.
Old Mar 15, 2020 | 11:50 AM
repairmatt's Avatar
repairmatt
Ah, I thought that was just for the bracket and didn't include the insulator. Thanks for the clarification! Can't wait to see how it runs, the driver side mount came out in two pieces.
Old Mar 16, 2020 | 06:33 PM
repairmatt's Avatar
repairmatt
Got everything replaced including the transmission mount, WOW what a difference. You cannot tell it's running when idling now, even in drive. Before there was some vibration through the steering wheel and seat and when coasting downhill it would feel like it was shuddering a little. Not anymore, butter smooth. Definitely worth the investment.
kevin1982
RX - 3rd Gen (2010-2015)
Sep 25, 2019 03:21 AM
difuria
Aug 20, 2017 04:51 PM
lserlohn
RX - 1st Gen (1999-2003)
Jul 5, 2016 08:10 AM
lexina
Jun 28, 2016 11:32 AM
