Engine Mount Torque Specs
I'm in need of the engine mount torque specs for the hydraulic front mount on an 02 ES300. There are three different bolt locations. First is the three bolts which mount the bracket to the engine block. Second the three bolts which mount to the vehicle frame. Third is the top bolt which connects the engine mount bracket to the mount itself. I need the torque specs for all three locations. Your help is appreciated.
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
The repair shop which services our vehicles at work looked up the specs for me. I can't guarantee accuracy of their information.
The single upper bolt is torqued to 70ft lbs.
The three bolts that connect the bracket to the engine block are torqued to 47ft lbs.
The three bolts which connect to the lower frame are torqued to 47ft lbs.
Thanks in advance!
Thanks in advance!
new_berlin
Jul 14, 2013 04:26 PM
vinny186
Nov 23, 2006 11:18 AM
