Steering calibration doesn't work and C1223 ABS
I was trying to do zero point calibration with the paperclip method, but I can't. (apparently - with Techstream you can only reset yaw/deceleration).
When I insert the paperclip - all I get is the abs light and flashing AFS light and nothing happens.
I also often get Check VSC/TRC OFF light when I make a long continuous turn in 1 direction (it goes away, when you turn the ignition OFF).
Here's what I saw, when I connected Techstream. When I tried to clear the codes - C1231 goes aways, but everything else remains.
Then I tried to RESET ABS/VSC via Techstream. Didn't help. Now I got this code C1336 that doesn't go away. (calibration of deceleration sensor undone).
AND.. I have a continuous Check VSC/TRC off light that appears every time start driving and turn the steering wheel.
DID the SIGNAL CHECK in the UTILITY menu - it threw these codes (they are not visible in general menu)
At this point - I don't know where to start. How to get rid of C1223 ABS code?
I have another steering angle sensor - I will try to replace it.
Please help. Thank you.
Try to remove negative cable terminal for about 5-10 minutes, connect everything again, and perform full health check in Techstream while engine is running. Please send the results here. Hopefully it’s something simple like the fuse for ABS system. I don’t any of your wheel sensors are bad, as well as abs. It’s gotta be something simple.
Also, I highly recommend avoid paper clip method for resetting zero points as I personally had experience when it caused all U errors which you currently see on your end. Techstream was able to clear them. are you using 8th version or newer?
On the straight road - when I almost stop - I can see that the steering pulls to one side. Tires are almost new 245/45/18, the battery is good.
I will remove the negative terminal tomorrow and clear the codes again, but I'm 100% sure ABS error won't go away.
If paperclip is not good for zeroing the steering sensor - how to do it? I think that Techstream calibrates ABS/Yaw sensor only, no?
Thank you!
Do you recall by any chance if the technician performed the full brake bleeding, Including abs?
Took off the negative battery wire for 10 minutes, tried to reset again with the paperclip and techstream - nothing
Both c1223 and 1336 codes stayed.
Will be visiting a specialist tomorrow and try to clear the codes with Launch x431
The same applies when you do a Reset Memory via the OBD2 port; afterwards, you need to do the equivalent of what Techstream calls Test Mode.
Thank you very much for sorting this out. I did exactly what you said - Reset memory, then Test mode after it. After this procedure - I tried to clear the codes and they all cleared for the first time! Even the C1223 ABS code.
BUT! They all appeared right after I started the engine and turned the steering wheel. So they are back again.
Can this be because I did this procedure not on a flat surface? The car was at the angle, I had to.
Or can it be the faulty YAW/Deceleration sensor?
Thank you!.
https://www.clublexus.com/forums/ls-...ce-needed.html
Hi! But I don't have codes / problems with solenoids. The Techstream - worked, but the codes are back again!
You said that you used Xpros device? That's Launch X431, right? My plan is to find a specialist who will reset the calibration and clear the codes with this device.
I was able to clear the c1336 code. With Launch x431. Calibration is done, but the abs c1223 code with the others u0073, u00123, u00124 are still there.
I connected Techstream and drove the car - my steering sensor is 100% good.
But I have a question about deceleration sensors 1 and 2. They are showing different numbers , is that right?
Can another calibration be needed or the yaw/deceleration sensor is bad?
