Pre-converters
Old Jan 10, 2020 | 12:33 PM
lionspaw's Avatar
lionspaw
Question Pre-converters
IS there such a thing as a pre-converter for a 2004 ls430? Mechanic recommended 2...… Plus gaskets 2 upper & 2 lower.....Idea for parts costs
Car has 270,000 but runs really good
Old Jan 10, 2020 | 12:49 PM
Yes but those are actually the main ones, each side of the engine has a cat bolted immediately to the manifold then a y pipe leading to a larger 2ndary cat that is not monitored by the system.
The OE cats are very expensive to the order of $800-1000 but if it was my car those are what I would use.
Old Jan 11, 2020 | 11:38 AM
jharris400's Avatar
jharris400
Why does your mechanic recommend to replace the converters? If your check engine light isnt saying they are bad I wouldn't replace then until it does. Even if the ecu says the cats are bad you can put a spacer on the oxygen sensors that will fool the ecu into thinking the cats are ok for a little while.
jpv7774
Apr 8, 2017 03:39 PM
Hornet
Oct 27, 2014 06:42 PM
cubbieblu7
IS - 1st Gen (2001-2005)
Jun 8, 2012 11:47 AM
mdrida7
Performance
Dec 12, 2011 05:39 AM
colexus79
Performance
Aug 31, 2006 06:55 PM
