Power window motor question
Old Dec 2, 2019 | 03:18 PM
shane8305's Avatar
shane8305
Default Power window motor question
Hello,
I read some comments and searched everywhere, but found no
definite answer.
02 LS430:
When replacing window lift motor - does it need to be programmed or installed
in certain position, or just simply replaced?
Thank you in advance
Old Dec 2, 2019 | 03:27 PM
Ellesse's Avatar
Ellesse
Post #3 in this thread was something I overlooked doing when replacing my motor!
zip tying the regulator so the new motor goes in right where the old one came out is something else they called out that I didnt do either. I feel like I hear a bit if a clicking sound when it goes up that I never heard before that might be why...
https://www.clublexus.com/forums/ls-...placement.html
Old Dec 2, 2019 | 04:10 PM
shane8305's Avatar
shane8305
Thank you for a link, but:
The guy says run motor for 10 sec. but the next post says 4 sec.
So which is correct?
Also FMI what does it accomplish? Motor is a motor and I guess
it will spin as long as a power is applied. Are there any limiters built in?
Tx
Old Dec 2, 2019 | 04:24 PM
Ellesse's Avatar
Ellesse
They are anti clip/ pinch motors
Old Dec 2, 2019 | 05:21 PM
shane8305's Avatar
shane8305
Thank you whatever that means. Would you please elaborate.
So which one is correct: 4 or 10 sec?
Tx.
Old Dec 2, 2019 | 05:48 PM
Ellesse's Avatar
Ellesse
10 will work. Make sure you set it up by doing the manual up and down, and them test the auto up, before you put the door back together, taking it apart again sucks
gwkasza
Sep 9, 2019 09:20 AM
Harrellsm
RX - 1st Gen (1999-2003)
Aug 1, 2015 07:28 AM
greens14
GS - 1st Gen (1993-1997)
Sep 22, 2011 02:13 PM
grego2
Jan 7, 2008 09:11 PM
