Master Remote
On the 3 button remote I received with the car the proximity and the door lock/trunk buttons have never worked .
I have had always to put the key into the ignition lock to start the car .
I have an aftermarket door lock/unlock remote which is spliced into the drivers door .
That's as the car came .
I have pulled apart the master key and i think fixed it ??When you push a button the red light flashes on and that is for all three buttons...does this mean it is now working ?
I have bought another secondhand 3 button key and have programmed it to start the key if I insert it into the ignition lock but I'm unable to program in the proximity or the door lock/unlock .
Perhaps I need to remove the aftermarket door lock spliced into the door loom ??
I;m not sure and if my master proximity is not working how do I program in the replacement master /
All help/input will be very greatly received .
Keyless Entry Programming. Lock. Unlock. Trunk. (TTT notes)
1. Sit inside the car. Close the driver’s door. All other doors closed also.
2. Lock the doors with the lock button.
3. Start the car with the original working master key. Wait a few seconds. Turn off the car and remove the original working master key.
4. Open the driver’s door by pulling on the handle. Do not unlock with the button or manually unlock. Just pull the handle and Open the door. Driver’s door is now Open.
5. Within 5 seconds, Insert and Remove the original working master key from the ignition switch TWICE. (In Out In Out).
6. Within several seconds, Close and Open the driver’s door TWICE. (Close Open Close Open).
7. Insert and Remove the original working master key from the ignition switch. (In Out).
8. Close the driver’s door. (Close).
9. Within several seconds, Open and Close the driver’s door TWICE, adding one final Open. (Open Close Open Close Open).
10. Insert original working master key into the ignition switch.
11. Close the driver’s door. (Close).
12. Switch ignition ON then OFF ONE TIME only - this will put the car in ADD mode.
13. Remove the original working master key from the ignition.
14. System should now Lock and Unlock vehicle one time automatically.
15. Within several seconds, on the new key being programmed, press and hold UNLOCK button followed immediately with LOCK button so that you are holding down both buttons at the same time. Hold them for a few seconds. Release the buttons. (The original instructions indicate to depress the buttons simultaneously, which did not seem to work for me after several tries, so I varied how to push the buttons.)
16. Within 3 seconds, press and release UNLOCK button.
17. System should now Lock and Unlock the car once to confirm registration of the new key. (or twice to indicate registration has failed per the original post)
18. Exit programming mode by opening driver’s door.
19. Test Keyless Entry functions on the new key. Lock. Unlock. Trunk.
These steps FINALLY worked for me!!! Good luck!!! TTT
Security Immobilizer Programming. Start Engine. (TTT notes)
1. Have all windows up and doors shut.
2. Stand outside the vehicle.
3. From outside, Lock the doors with the original working master key by pressing LOCK button.
4. From outside, Unlock the driver’s door with the original working master key by pressing UNLOCK once.
5. Enter the vehicle, and close the driver’s door. Press the lock button (by the window switches) once to lock the doors.
6. Start the car for about 5 seconds, then turn the car off, and remove the original working master key.
7. Insert the original working master key back into the ignition.
8. Within 35 seconds, do the following (Make these next moves very precise and without any variation in your motions, which seemed to help):
a) Turn the key to the ACC position, being careful not to turn too far. (key in ACC position)
b) Turn the key from ACC to ON position five times ending in the ACC position. (ON ACC, ON ACC, ON ACC, ON ACC, ON ACC); do this somewhat quickly in about 1 second cycles for each ON ACC motion.
c) Open and Close the driver's door SIX times. (Open Close Open Close Open Close Open Close Open Close Open Close). Do not unlock the door with the button – just pull the handle and the door will unlock during your first Open.
d) Remove the original master key
9. Within 10 seconds insert New Key into the ignition, and turn to "ON".
10. Leave the New Key inserted until the red security light stops flashing (mine took about 60 seconds; other posts say up to 90 – 120 seconds).
11. After the flashing stops, remove New Key from ignition.
12. Depress the brake pedal forcefully ONCE to exit the programming mode.
13. Wait 15 seconds to allow the computer to reset.
14. Test New Key by inserting into ignition. The red security light should go off. Attempt to start the vehicle.
https://www.clublexus.com/forums/ls-...sponder-2.html
Will it be the same using the after market fob that lock/unlocks door...or not ??
(A discussion of aftermarket issues https://unitedlocksmith.net/blog/the...ronic-car-keys)
Any chance you may call the manufacturer or distributor...?
Have managed to get my original master to now lock/unlock the doors plus the trunk button now unlocks the trunk...whoo hooo !!
Also the proximity for the key works , no longer have to insert the fob to start the car .
Holding the lock button now also closes the windows and the sunroof like it should .
However the proximity for opening the door does not work ??
Nor can I lock the door with the rubber button on the handle WTH !!
How can it be the proximity works for the ignition but not the door ?
Currently ( as in right now ) have the door panel off and removing the after market door/unlock spliced in system .
We will see if that makes any difference .
Have worked it out !!
I was just putting my whole hand in between the lever and the door the same as I do on my wife's IS250 when I drive it , however after looking at the 430 manual you need your hand on the outside of the door handle to trigger it !!
Problem solved .
