Has anyone dealt with these codes before?
Old Oct 6, 2019 | 02:14 PM
Neverdone's Avatar
Neverdone
Default Has anyone dealt with these codes before?
So I pulled all these codes with my reader today since I've been having christmas lights all on the dash, but not all the time.
C1246-The Skid Control ECU sets the OBDII code when the Wheel Cylinder Pressure Sensor is not to factory specifications
c1249-stop light switch
c0278-open in ABS solenoid in relay circuit
c1223-ABS control system malfunction
ok, so I'm pretty sure the c1249 and c1223 will be taken care of with the brake light switch from what I've read, but the other few codes I'm not so sure about, any insight on these?
I'm really hoping fixing the brake switch is the be all end all to these issues.
Old Oct 6, 2019 | 02:36 PM
bradland's Avatar
bradland
Aftermarket switch is about $20 and a genuine Toyota switch costs about twice that. Kind of inconvenient to get to if you're planning to replace it yourself. Not impossible just uncomfortable...
I'd tend to agree, replacing the switch should remedy at least 2 if not all 3 codes.
Old Oct 6, 2019 | 02:41 PM
Neverdone's Avatar
Neverdone
Here's another question, where is the brake switch all under the brake pedal?
Old Oct 6, 2019 | 03:02 PM
bradland's Avatar
bradland
See attached PDF
(The diagram is for a LS400. The 430 Svc Manual file exceeded the forum file size for attachments)
File Type: pdf
Old Oct 7, 2019 | 08:21 AM
Neverdone's Avatar
Neverdone
See attached PDF
Thanks man I'll try it and update the thread with my findings.
TMRYAN
Dec 28, 2022 12:54 AM
yr0169tw
12
Nov 13, 2007 08:49 PM
