Lexus dealer only 90116-14016 should be less than $10 ea
It doesn't even show up as a Toyota part.
The nuts, if you need them, are 90178-14002
Thanks, you are a life saver. If I take the other side bolt off will the whole rack slip off enough to get to it or will I have to disconnect the steering shaft?
Trying to decide if this is something I can manage or I'll just have to go to mechanic.
Hard to say without seeing where it broke. Try it and see...
Just be careful with the hydraulic lines and apply match marks before disconnecting the intermediate shaft.
