Headlight Restore Comparison- Polish vs Clearcoat
Old Aug 25, 2019 | 09:21 AM
biacs's Avatar
biacs
Default Headlight Restore Comparison- Polish vs Clearcoat
We all have headlights. We all have hazing. A couple years back I used the Sylvania restore kit and they looked good and it lasted about 2 years. This year I bought the Mothers Plastic Polish / Headlight restore kit at Oreilys. I also had a 2 oz bottle of clearcoat I got off Amazon.
Process:
  • Clean headlights with rubbing alcohol
  • Mask around headlights
  • wet sand lenses w 600
  • wet sand lenses w 1000
  • wet sand lenses w 2500
  • Applied clearcoat w a foam brush, let dry overnight - passenger side
  • Polished the clearcoated (passenger) lens with the mothers kit to brighten
  • Polish driverside with just the Mothers kit using my drill
The Clearcoat side is MUCH brighter and crisper! The Mothers polished side certainly looks fine- nothing to complain about. You wouldn't give it a second glance to be honest. But the brushstrokes do leave a sort of striping on the lens, you con only see if you get very close. I assume the clearcoat would last a time
If we polished these and had a body shop shoot the lenses with clear, no striping correct? Does using clearcoat on the lens set off any red flags with you guys?
Old Aug 25, 2019 | 09:43 AM
biosurfer1's Avatar
biosurfer1
Clear coat is a pretty common fix for headlights as a last step, don't see anything wrong with it, and I would think it would take a competent shop about 30 seconds to shoot them.
Old Aug 25, 2019 | 09:46 AM
Bocatrip's Avatar
Bocatrip
Clearcoating is the only way to go for a long lasting crisper finish. I had mine done a few years ago by a mobile outfit and they still look good sitting out in the Fl sun.
Old Aug 26, 2019 | 07:21 AM
biacs's Avatar
biacs
Is there an aresol or sprayable clear-coat of some sort folks have used?
Ideally we dont have to deal with body shops. They usually ask for $300 to touch anything.
And like we mentioned- 30 seconds to shoot and we can wetsand at home.
Old Aug 26, 2019 | 08:38 AM
Peacebay's Avatar
Peacebay
I used
this 2K clear aerosol this 2K clear aerosol
to do my motorcycle wheels and it is legit! Goes on super thick and has lasted very well so far.
Just make sure to wear a mask and have good ventilation.
Old Aug 26, 2019 | 08:39 AM
Kansas's Avatar
Kansas
I've done a number of headlight lens restorations using a variety of commercial kits including the one from Sylvania that have you wipe on the clear coat with a microfiber towel but I think I'm going to try the Chris Fix method next time using a Rustoleum clear coat product. Here is a link to the YouTube video and an image of the Rustoleum product he used:
I've gotten the best results from the Sylvania kit but its clear coat usually starts to visibly degrade by the two year mark. Maybe the Rustoleum clear coat will last longer. I'm going to get Xpel headlight film installed on the next new vehicle I purchase to see how well it works. We have 3M paint projection film on the front ends of two current vehicles and it has worked great.
Old Aug 26, 2019 | 08:43 AM
FunFact's Avatar
FunFact
Originally Posted by Kansas
I've done a number of headlight lens restorations using a variety of commercial kits including the one from Sylvania that have you wipe on the clear coat with a microfiber towel but I think I'm going to try the Chris Fix method next time using a Rustoleum clear coat product. Here is a link to the YouTube video and an image of the Rustoleum product he used: https://www.youtube.com/watch?v=UEJbKLZ7RmM
It is not the Chris Fix method, don’t give him credit for something he didn’t create. All he does is take methods from other people and doesn’t give credit where it’s due.
This method was on Autogeek and other places long before he thought of stealing it.
Old Aug 26, 2019 | 08:57 AM
Kansas's Avatar
Kansas
Of course it isn't "his method" but his video is a nice, clear, readily available and even fun tutorial that identifies all the products required to be successful.
There's nothing wrong with borrowing ideas and repackaging them.
Old Aug 26, 2019 | 09:35 AM
2KHarrier's Avatar
2KHarrier
I'm in the process of restoring an older bass guitar, and just finished shooting the clear on the color finish. The paint used is Nitrocellulose, which is extremely durable.
I wonder how that would bond on a clear plastic lens? Just a thought...
Old Aug 26, 2019 | 10:59 AM
YODAONE's Avatar
YODAONE
U.V. resistant properties are critical to durability and function of clearcoat applied to headlamp lenses...
Old Aug 26, 2019 | 11:53 AM
Kansas's Avatar
Kansas
Then I wonder how this Rustoleum product with its advertised "Ultimate UV protection" would work: https://www.rustoleum.com/product-ca...-clear-topcoat
I have been assuming that the "High Gloss" version would be better for headlights than the "Dead Flat Clear" version but what do others think?
Old Aug 26, 2019 | 11:54 AM
caverman's Avatar
caverman
I used the Rustoleum clear UV on my LS and GS. You have to be very careful to not get fish eyes. Actually, I think there wasn't a single headlight I did with the rattle can spray that didn't have at least one or two small fish eyes but some were very minimal and not a big deal. I personally felt that the clear slightly changed color fairly quick. I ultimately threw in the towel and had them done professionally where they used a chemical to prep the lens and then they wiped on what is probably just a clear coat and they turned out really well. It's been well over a year for both my LS and GS and they are still looking good.
Old Aug 26, 2019 | 01:24 PM
Euro09's Avatar
Euro09
I clearcoat mine too,
Old Mar 13, 2021 | 07:24 PM
equsnarnd's Avatar
equsnarnd
Anyone use the Cerakote kit to restore headlights?
Old Mar 13, 2021 | 07:25 PM
equsnarnd's Avatar
equsnarnd
I need to replace a passenger headlight assembly due to damage. Anyone have a preferred source with quality products other than the dealerships?
