Headlight Restore Comparison- Polish vs Clearcoat
Old Mar 14, 2021 | 05:54 PM
YODAONE's Avatar
YODAONE
Originally Posted by 04Ultra
There is a company called Eastwood that sells a rattle can clear coat that has a true 2-part system. Clear and then a separate catalyst you add by piercing a special fitting on the bottom of the can. You have 48 hours to apply the clear before it spoils in the can but from the headlight restos I’ve seen done with it the finish comes out perfect like a typical body shop pro would apply.
Here is a link to the clear:
https://www.eastwood.com/eastwood-s-...tte-clear.html
Here is a diy video of a guy using this clear and a basic at home diy restoration without any specialized tools to get a good result.
https://m.youtube.com/watch?v=Xubwpeuqm-E
Is there any information on the products use on plastics and UV shielding properties?
Old Mar 14, 2021 | 06:53 PM
430SLOwner's Avatar
430SLOwner
For what it is worth; this guy from the Paint Society channel likes Eastwood's 2K UV protection clearcoat in a can ...
Sorry, just noticed video was already in the message to which you replied....
Old Mar 15, 2021 | 04:06 AM
equsnarnd's Avatar
equsnarnd
I saw this on YouTube a few days ago. I have the Cerakote kit that I'm going to try. It lays down a ceramic coat. But this guy says the clear coat he used is better than the factory coating and it should last a lifetime. Strong statement.
Know of any places to purchase headlight assemblies that are quality products without the dealership prices?
Old Mar 16, 2021 | 10:41 AM
caverman's Avatar
caverman
Make sure to look at what it takes to replace the headlights. If you have a 2004 - 2006 you'll be removing the front bumper.
Old Mar 16, 2021 | 05:11 PM
equsnarnd's Avatar
equsnarnd
2000 rx 300.
Old Mar 16, 2021 | 06:06 PM
nvwls's Avatar
nvwls
I need to replace a passenger headlight assembly due to damage. Anyone have a preferred source with quality products other than the dealerships?
There's many on ebay and random parts sites in the 300-600 range. Keep in mind you can also buy a new lens for approx. $150. (https://www.amayama.com/en/part/toyota/8117150270, https://www.amayama.com/en/part/toyota/8113150270) Opening and resealing the headlights with a new lens isn't too bad. You just need a heat gun and sealant. Even I, a complete amateur, was able to do it.
Removing the front bumper was a bit of a pain, but considering it was the first body panel I've ever removed, it was not that bad. Three bolts and some clips and you're good. If you're only doing one headlight you don't need to remove the entire bumper, just free one side and have someone else pull it forward while you remove the headlight. Taking out the headlight, opening, resealing and reinstalling took about 1 hr.
Old Mar 16, 2021 | 06:20 PM
equsnarnd's Avatar
equsnarnd
I found a used OEM headlight assembly on Ebay for $60. Made in Japan by Toito.
Old Mar 16, 2021 | 07:22 PM
nvwls's Avatar
nvwls
For 01-03 or 04-06?
Old Mar 17, 2021 | 07:03 AM
BigBoomer's Avatar
BigBoomer
Don't forget that in Japan they drive on the correct side of the road, so that headlight will be setup for righthand drive, so you may be blinding other drivers when on dipped beam as the beam patterns are not flat.
flattire
Dec 3, 2014 02:00 AM
myculito
Mar 29, 2013 11:29 AM
sdwtchlvr
Automotive Care & Detailing
Nov 7, 2011 01:17 PM
