VSS/speed sensor tap location?
Old Aug 19, 2019 | 08:16 AM
boosteddsm's Avatar
boosteddsm
Default VSS/speed sensor and ebrake tap location?
Hey guys, trying to install an aftermarket head unit and need to tap into the speed sensor. I have a non-nav 03 and I've searched and searched and can't find where it's located, any help appreciated!
Also, the parking brake sensor wire location would be very helpful too!
Old Aug 19, 2019 | 01:07 PM
rkw77080's Avatar
rkw77080
I do not have wiring diagram specifically for the non-NAV LS430. But, I suspect all LS430 come with the same wiring harnesses regardless. Please look for the M4 connector behind where the Multi-display located (see location below)
Terminal 5 on M4 (SPD) is for the speed signal and, terminal 13 (PKB) is for the parking brake.
Old Aug 20, 2019 | 06:52 AM
boosteddsm's Avatar
boosteddsm
Thanks so much, I'll try to take actual pictures of the connectors and wires for future reference.
Old Aug 25, 2019 | 09:04 AM
boosteddsm's Avatar
boosteddsm
Found out the wiring harnesses are different between nav/non-nav. Easiest place to tap for VSS on a non-nav car is the violet-white wire on the harness that connects the instrument cluster. Pull bezel then pull cluster, there's only one harness plugged in there, C12.
Old Aug 4, 2020 | 02:25 PM
Tom Young's Avatar
Tom Young
Unhappy Also need help 2005 LS430 Code P0500
Took 2005 LS430 to dealer for P0500. They told me it was a $5000+ ABS Actuator. My BlueDriver says it is the vehicle speed sensor, under $20. Is this something a good DIYer can do or is replacing the speed sensor very difficult? Where is the vehicle speed sensor located? On the transmission driver side? Upper or lower?
Looked at many pictures online and am still confused.
Thank you in advance.
Old Aug 4, 2020 | 02:49 PM
bradland's Avatar
bradland
There are two but they both use the same part number.
https://www.lexussouthatlantaparts.c...&searchString=
Old Aug 4, 2020 | 05:34 PM
Tom Young's Avatar
Tom Young
Thank you much Bradland for the quick reply. Do you know if this is something a good DIYer is capable of doing, or is it a difficult job?
Old Aug 4, 2020 | 06:27 PM
bradland's Avatar
bradland
Replacing the sensor is extremely simple BUT there's very little room on the side of the Trans. Just enough room for a wrench or a medium-sized hand but not both...
I'd pull both and test them with a multimeter first before buying any replacements. You might only need one...
Old Aug 4, 2020 | 06:47 PM
Tom Young's Avatar
Tom Young
Very grateful. One last question. The scanner says it is the vehicle speed sensor "A" circuit. Does this tell you which sensor it is?
Thanks again
Old Aug 4, 2020 | 07:27 PM
rkw77080's Avatar
rkw77080
Thanks again
Attached are the troubleshooting procedure pages for P0500. Hope they're helpful.
File Type: pdf
Old Aug 4, 2020 | 07:52 PM
430SLOwner's Avatar
430SLOwner
Is there more room to work where the sensor is near the output shaft of the transmission than where the sensor is near the torque converter? If so, does it make sense to check the easier to reach sensor first...?
Old Aug 4, 2020 | 08:05 PM
bradland's Avatar
bradland
Thanks again
IIRC 0500 is associated with the rear, output shaft, sensor.
A 0717 code points at the forward, input sensor.
Old Aug 4, 2020 | 08:58 PM
Tom Young's Avatar
Tom Young
Thank you, thank you, thank you. You've given me just what I needed. You are the man!!
Tom
Flufferiou
Aug 4, 2006 10:35 AM
