I've watched the walk throughs online. Clearly the springs and installs make this a tougher job to tackle on the garage floor. There always seem to be extra struggle that they snip out of the videos to make it seem easier.
If I have the $$ to pay a pro - should I have an Indy shop handle the installs?
The car has given me a lot of great miles, so I'm not afraid to spend some $$ on the upkeep!
I did it myself.
I was going to coilovers though so there was no need to swap springs to new shocks etc., and the coilovers are shorter so easier to get in too.
I think you could still do it yourself, the diys on this site were extremely helpful. The rears were tricky, I did the alt method of someone standing on the hub to get them out so that saved time too.
Please take a look at the links below for DIY tips and tricks.
No, but girls are...and she did a fine job on mine
Do people commonly replace the coils?
In my experience, 99% of the time it's just the shock, so you're able to compress the spring on the old shock easily while it's on the shock body, and then only decompress when you're putting it in the new one, right?
I recently replaced both front struts using the old coils. The coil compressing tool rented from Advance Auto worked just fine.
Words of advice as I learned this from doing my own. Place the rubber bumpers back inside the dust cover if new ones are not purchased or come with your struts. Also, when pulling the front passenger side strut assembly out, be careful not to hit the connector wire that is attached to the harness on the steering knuckle. This wire is attached to your ABS, brake wear, and wheel speed sensors.
Struts are probably one of the easiest jobs to do, that from a layman's viewpoint looks very difficult. With regards to the springs, I have taken the strut assembly to a local shop in my neighborhood and had them swap the spring over from the old strut to the new one.
The only reason I replaced my coils was because I switched from a Sport suspension to the base suspension.
Just curious as to why you switched from the Sport suspension to the base suspension. Eventually, I want to do the exact opposite, as in switching TO the Sport suspension.
Lots of reasons, but mainly because I wanted the LS to be "smoooooth and easy, baby". (imagine Barry White saying that)
I didn't feel the Sport ride fit my expectations for the car. I'm happy with the swap.
Works for me. The base LS is quite "lush".
Do you have any way of comparing the Sport side to another vehicle? Is it really that much firmer/rougher?
Quite honestly, if I could manage somehow to lower the ride height by about an inch total all the way around without effecting that smooth ride, I'd be perfectly happy. Maybe just some beefier sway bars, but that's it.
which coilevers did you use and how much was it for all 4? I'm looking at the OEM sport struts + tanabe springs + mounts and that's getting close to $1000 so I'm wondering if coilever would be better
I think what is being referred to (and I don't know if this car has them and I am not for them) are the "quik" struts. They are basically intended to save labor for shops, and have caught on with shade trees too since they can be dealt with as an entire unit, rather than separating the components to include compressing the spring.
What I will say is this--on my wife's GM KYB makes a unit for $185. If you add up the price of each individual component using OE, it will easily exceed $400. No way no how they are of the same quality. So what a muffler shop does is they get that $185 part for maybe $70, charge $400 parts and $400 labor, and in reality, there was little labor needed because it was all in one. But this is your own car, why do that to yourself? I did it with my Nissan and the results were terrible (monroe quik struts from rock). Live and learn.
My suggestion on this one is use original parts (I wish it were like BMW where you have maybe 5 options from Bilstein alone all costing less than OE).
Unfortunately, as our cars age and values plummet even further, owners may start using these cars as "beaters". When that time comes (if it hasn't already), many owners will look to save every penny. Personally, as long as I've owned my car OEM is the only way I'm replacing parts. It's another reason my car has treated me so well for so long. Those quik struts are most likely junk.
I'll add my opinion. I replaced my front struts (reused the springs) in my driveway last year. I used a spring compressor from HF. Using the notes I found on here, it was not a technically difficult job, but if I had to do it again, I would find a shop to swap the spring for me. That part of the job was a little nerve-wracking and took the longest. Not to mention, put the most strain on my back since I did that part holding them with my foot on the ground while turning the nuts on the compressor.
In my case I used the bc coilovers. Apart from being able to dial in whatever height you prefer, you can adjust the firmness as well. I'm very happy with them.
