passenger window
Old Aug 9, 2019 | 05:28 AM
johnnylt's Avatar
johnnylt
Default passenger window
Hello All
I have a 2005 LS430 , I lowered the passenger window and when I went to raise it , it went up then came back down 1/2 way it keeps doing this? (Motor was replaced last year) another thing last week kids were playing around with it .
Any Ideas please
Old Aug 9, 2019 | 05:48 AM
rkw77080's Avatar
rkw77080
According to the owner's manual, this is the behavior of "Jam Protection" at work... The ECU detected what it thinks is an obstruction. Check the window glass track, and also make sure the glass is not tilting (which can bind).
Old Aug 9, 2019 | 05:56 AM
johnnylt's Avatar
johnnylt
Thanks for the quick reply , I checked and everything seems to be in order ,no obstructions and everything Is straight , if I hold the switch while its going up and don't let go it will stay up but then returns to the same behavior when I lower it again , is there a way to like reset it ?
Old Aug 9, 2019 | 07:20 AM
johnnylt's Avatar
johnnylt
All fixed!! so people know ,lower window and continue to hold switch down after window is all the way down donot let go for 10 seconds then raise window all the way up donot let go of switch continue holding in for 10 seconds then let go , that's it ,window goes and up and down as it should and auto works as well
Dmiric
Feb 15, 2018 05:47 AM
appsdba
RX - 1st Gen (1999-2003)
Dec 11, 2014 07:47 PM
biotix
Mar 16, 2007 09:36 PM
mole
Oct 4, 2006 10:19 AM
