Found an obd2 scanner that works!
Old Aug 5, 2019 | 01:31 PM
Bocatrip's Avatar
Bocatrip
Default Found an obd2 scanner that works!
For quite some time I've have a PO440 DTC for the evaporative emission system triggering my check engine light every couple of months. After many attempts to repair it (everything points to the charcoal canister), I usually ask my Indy to clear the CEL during oil changes or routine visits. I don't like asking him to do it. I previously picked up a Zurich from Harbor Freight that didn't have the ABS feature and after erasing the CEL....all the ABS, slip, and VDC lit up until I used the paper clip method to eliminate it. I was told that any OBD2 used must have the ability to read ABS codes which this Zurich didn't do.. I was able to return it. Most retail stores do not allow returns for OBD2 scanners. I just picked up from Pep Boys an Actron CP9660 (with the promise I could return it in 30 days for any reason) and it worked perfectly. CEL is off and no ABS,SLIP, or VDC lights came on. I found a coupon and was able to get it for $85 including tax. All the cheap OBD2 scanners for under $50 won't work without triggering the ABS lights. My question is.....this Actron CP9660 works for me but does not illuminate(which makes it hard to read)....for $111 plus tax I can get the Actron CP9670 has back lighting, does more diagnostics including checking alternator and battery plus other items. I don't use scanners at all other than this one time for the CEL in my Lexus. Should I invest in the better CP9670 for any future use or is it a waste? What scanners do you guys use?
Old Aug 5, 2019 | 01:55 PM
Lavrishevo's Avatar
Lavrishevo
Techstream and my MacBook Pro. Windows via virtual machine.
Old Aug 5, 2019 | 03:11 PM
TriC's Avatar
TriC
It sounds like the small additional cost makes the better scanner well worth the money.
Old Aug 5, 2019 | 03:16 PM
Bocatrip's Avatar
Bocatrip
My thoughts exactly! Thanks!
Old Aug 5, 2019 | 03:55 PM
LS430FL's Avatar
LS430FL
Can't Carista do everything that you want plus allow you to customize features on the Lexus as an added bonus?
Old Aug 5, 2019 | 04:29 PM
Bocatrip's Avatar
Bocatrip
Not available for the LS430
Old Aug 5, 2019 | 04:41 PM
k7q's Avatar
k7q
I used scanmaster on android and it works fine for me to check cel. It doesn't trigger vsc when I cleared the code.
Old Aug 5, 2019 | 07:41 PM
Bocatrip's Avatar
Bocatrip
I'm absolutely not savvy when it comes to technology, so anything advanced would be a challenge for me. I'm better off with a small hand held OBD2 scanner even with it's limitations.
AyyLS400
May 19, 2018 08:33 PM
goozer
Sep 24, 2016 07:43 AM
anon1m0us
GX - 1st Gen (2003-2009)
Sep 15, 2013 07:01 PM
mmman1963
Maintenance
Jan 28, 2013 07:00 AM
GSRSRT
May 26, 2011 08:56 PM
