Nav bezel scratches - Cheap, easy solution!
Old Oct 9, 2021 | 07:24 PM
  #31
cyclehead's Avatar
cyclehead
Does anyone have the missing (deleted?) details on vinyl wrap to do this repair?
Old Oct 9, 2021 | 07:26 PM
  #32
Jamblaell's Avatar
Jamblaell
8th Gear
3M 1080 Matte Metallic Charcoal Air-Release Vinyl Wrap Roll (1/2ft x 5ft)
Amazon Amazon
Old Oct 9, 2021 | 09:14 PM
  #33
cyclehead's Avatar
cyclehead
Thanks! Any idea what the template looked like? The curved portion looks tricky. I’d be tempted to use knifeless tape and do it in two separate pieces.
Old Nov 14, 2023 | 06:54 AM
  #34
toszy's Avatar
toszy
2nd gear
Team. As the video attached to this awesome repair method is no longer available could you please advise if the bezel needs to be removed / disassembled to apply the vinyl film or ic can be done on the assembled one?
Old Nov 14, 2023 | 07:23 AM
  #35
Stevequad's Avatar
Stevequad
No, the bezel does not need to be removed. I suggest you have a sharp Exacto knife, to trim out the edges, careful not to cut the plastic bezel. You WILL mess it up at least once, so be prepared for that, I did. The hardest part for me was forming the corners, at the bottom of the nav screen. I used a hair dryer to soften up the vinyl, and pushed it down with my finger. That is the trickiest part. If it doesn't sit just right, I put a slit in it, to help it form properly.
Good luck. I did mine a long time ago, and it still looks great.
Steve Q.
Old Nov 14, 2023 | 07:32 AM
  #36
toszy's Avatar
toszy
2nd gear
Thanks Steve. That helps a lot! I was afraid I will be forced to unscrew everything from the bottom to the top to get the bezel out
Luap
GX - 1st Gen (2003-2009)
Feb 15, 2019 05:52 PM
LVPUNK
Jul 16, 2018 11:43 AM
vfr700f2
May 16, 2017 08:16 AM
FutureOwnr
Jul 22, 2013 08:30 AM
Overtaxed
Maintenance
May 18, 2001 03:18 PM
