Timing belt
Old Dec 15, 2018 | 07:48 AM
cd15's Avatar
cd15
Default Timing belt
I just resently purchased a 06 ls430 with 162,000 on the clock.the car history report does not show the timing belt ever being changed.should i have it done as soon as possible or maybe later?
Thanks,
Old Dec 15, 2018 | 07:58 AM
TriC's Avatar
TriC
ASAP by all means. Be sure to also have the tensioners and idler replaced as well as the timing belt and water pump.
Old Dec 15, 2018 | 08:03 AM
Johnhav430's Avatar
Johnhav430
Is there any evidence under the hood, such as an Aisin sticker or a Toyota sticker? Mine is also not on carfax or Lexus, but I paid for it at my indie. So those records don't always show everything.
Otherwise, the worst thing that could happen is you change it and it has 162k on it, or you change it and it was done at 90k, so you are 18k early. Not much downside in doing it.
Old Dec 15, 2018 | 12:26 PM
lextout's Avatar
lextout
sometimes there changed without a lable, one way to check is to remove the timing cover and check the belt for stress cracks
Old Dec 15, 2018 | 12:50 PM
430's Avatar
430
Change it. In addition to timing belt, tensioner, pulley, water pump, etc, you should consider changing the radiator. It will be removed for the timing belt change and they are under $100. It is worth doing while you have the engine pulled apart.
Old Dec 15, 2018 | 02:07 PM
RA40's Avatar
RA40
Good point on the radiator. With proper coolant changes, the OEM radiator run 160-220K miles. My shop relayed 180K is pretty average lifespan on those OEM Toyota radiators.
Old Dec 16, 2018 | 11:16 AM
2KHarrier's Avatar
2KHarrier
I installed a new radiator at 200k when I did the TB on my 2001 back in April, and it was ready.... The radiator on the 2005 looked pretty good when I did that TB, but that car had 59K on the odo.. Many fewer cycles...
Old Dec 16, 2018 | 03:17 PM
05ls430518's Avatar
05ls430518
I would just change it even if someone showed me a recipt that it was just done I would still change it, worth the piece of mind.
Old Dec 16, 2018 | 04:09 PM
Htony's Avatar
Htony
Wow, better hurry.
SCLover777
Feb 2, 2009 07:57 PM
swat1727
Dec 11, 2008 12:44 PM
wheel
Oct 27, 2003 08:51 PM
SilverFlare
Maintenance
22
Sep 4, 2003 06:32 PM
