Speedometer not working
Old Aug 7, 2018 | 03:01 AM
awdxtc's Avatar
awdxtc
Default Speedometer not working
So yesterday on my lunch break I left work and the speedometer was not working the brake light is now on and the fuel gauge seems to intermittently fluctuate. None of these problems were present when I put in to work in the morning. I went how the battery and alternator tested and both of those seem to check out OK.
Old Aug 7, 2018 | 03:00 PM
rkw77080's Avatar
rkw77080
Intermittent electrical problems are the most difficult to troubleshoot. Does your tachometer work? Do you have DTC (e.g. P0500)?
The brake light may be unrelated to the speedometer issue. Have you tried to pull on the hand brake release lever to see if it will clear?
Old Aug 7, 2018 | 03:06 PM
awdxtc's Avatar
awdxtc
I'm having the codes checked tomorrow, I tried releasing the brake but no luck. The tach does work.
Old Aug 7, 2018 | 03:47 PM
pmesfun's Avatar
pmesfun
Try tapping the dash above the cluster, maybe it will bring the speedometer back to life. I had this issue in very cold weather on a 99 LS, not sure if a common issue with the 3rd gens but worth a try.
Old Aug 7, 2018 | 04:21 PM
rkw77080's Avatar
rkw77080
The tachometer works, so we can rule out a blown fuse (since both have a common power source). The next thing to check is the Vehicle Speed Sensor, possibly a loose connector, broken wires, or faulty sensor.
mckellyb
Jun 10, 2025 08:34 PM
phermes1
Maintenance
Feb 6, 2012 03:49 AM
johnball
Dec 13, 2010 07:23 PM
habsa56
Apr 9, 2010 04:51 AM
taeng
Jun 13, 2007 11:43 AM
