2001 Celsior headlight cutoff pattern
Old Mar 31, 2018 | 02:38 PM
peenlrd's Avatar
peenlrd
Default 2001 Celsior headlight cutoff pattern
Is there a way to adjust the cut off pattern on 2001 Celsior in order to pass DOT without having to buy new headlights?
thanks
Old Mar 31, 2018 | 02:54 PM
05ls430518's Avatar
05ls430518
thanks
use the adjustment screws
Old Mar 31, 2018 | 03:22 PM
peenlrd's Avatar
peenlrd
Can I adjust the pattern with them or just angle them down?
Old Mar 31, 2018 | 04:12 PM
05ls430518's Avatar
05ls430518
you can angle them down here is a video that explains the proper way to do it apply whats in the video to your car.
https://m.youtube.com/watch?v=qDudMM4J-ZE
Old Mar 31, 2018 | 04:49 PM
peenlrd's Avatar
peenlrd
Thanks, but that is not what I am trying to do.
Old Mar 31, 2018 | 04:50 PM
rkw77080's Avatar
rkw77080
Please take a look at Post #8 on the link below. You have to use the "painted" light bulb for the 2001-2003 model, unlike the 2004-2006 model LS430, which has a different reflector to shape the light pattern.
https://www.clublexus.com/forums/ls-...ght-bulbs.html
Old Mar 31, 2018 | 04:54 PM
peenlrd's Avatar
peenlrd
Ok, so the pattern is determined by the bulb in the UCF30s?
thanks
Old Mar 31, 2018 | 07:52 PM
rkw77080's Avatar
rkw77080
thanks
Yes, the wrong bulb will give your low beam the oval pattern like that of the high beam.
Mar 12, 2014 05:02 PM
miniround
Mar 23, 2008 05:39 PM
mcgong
Automotive Care & Detailing
Jan 26, 2003 11:52 PM
