Cruise control 108kmh problem!!
Old Mar 28, 2018 | 12:40 PM
Make15's Avatar
Make15
Default Cruise control 108kmh problem!!
Hi. Have any one fix this Japan cruise control 108kmh problem on Toyota Celsior or LS430? I read about this problem on Soarer planet but i think that is different. I hope that someone have solution for this.
Thank you for answer.
Old Mar 28, 2018 | 06:46 PM
ibrahim83's Avatar
ibrahim83
What's the question?
Old Mar 28, 2018 | 08:56 PM
Make15's Avatar
Make15
Sorry my bad. Problem is that cruise control do not working over 108kmh.
http://soarercentral.com/sc-forum/messages/4570/72224.html?1146469586
Old Mar 29, 2018 | 10:47 AM
mhussien32's Avatar
mhussien32
Yes. I have the same issue.. Check the below thread. I realized that the ECU unit for some Japanese models is having those restirections, hence it needs to be replaced, which I'll never do for some stupid issue like this.
https://www.clublexus.com/forums/ls-...ntrol-max.html
Old Apr 26, 2020 | 08:49 PM
Ibraheem's Avatar
Ibraheem
10th Gear
Did you manage to find a solution? I have the same limit on my 2003 Celsior.
Old Apr 26, 2020 | 11:58 PM
Groot430's Avatar
Groot430
The LS400/Celsiors had a separate ECU for the cruise which had a J1 jumper switch in it .
The LS430 cruise thing is in the ECU as far as I can ascertain which means sending it to our Russian friend to have it removed , bonus is he can tweak the tune at the same time .
Dnepr98
Dec 16, 2014 06:14 AM
gvm
Oct 27, 2010 04:58 PM
