Heavy steering wheel
Old Mar 27, 2018 | 05:01 PM
Andyboy980's Avatar
Andyboy980
Default Heavy steering wheel
2002 ls430 I have changed the power steering pump and rack and pinion the longer I drive it’s the harder the power steering gets and the was a problem I had before changing parts. Can somebody please help me
Old Mar 27, 2018 | 06:38 PM
Andyboy980's Avatar
Andyboy980
I cannot remember seeing one
Old Mar 27, 2018 | 07:17 PM
Andyboy980's Avatar
Andyboy980
Yes I did and I can assume the selonoid is an Eletrical component
Old Mar 27, 2018 | 07:19 PM
Andyboy980's Avatar
Andyboy980
I will check with my mechanic because I cannot remember seeing him attached any thing to the rack
Old Mar 27, 2018 | 07:21 PM
Andyboy980's Avatar
Andyboy980
Thanks for the info I really believe that is the problem
Old Mar 28, 2018 | 04:02 AM
Andyboy980's Avatar
Andyboy980
Is it this called progressive power steering selonoid
Old Mar 28, 2018 | 01:05 PM
Andyboy980's Avatar
Andyboy980
I check my fused. Ox there are no such fused
Old Mar 28, 2018 | 01:38 PM
Andyboy980's Avatar
Andyboy980
I haven’t see that fuse look at the picture I sent you
Old Mar 28, 2018 | 04:19 PM
ls430w140's Avatar
ls430w140
You sent picture from another fuse box. RKW offered you to check your “fuse box in the driver’s side kick panel”. Locate the appropriate fuse at number 13 called ABS-IG and visually verify if it is not burnt or broken. On cars like LS430 it is always good to start at checking fuses first.
Old Mar 28, 2018 | 06:01 PM
Andyboy980's Avatar
Andyboy980
Fuse is good
Old Mar 29, 2018 | 09:47 AM
Andyboy980's Avatar
Andyboy980
Good afternoon I found the fuse box checked the fuse and it is good, what’s my next move? I really appreciate your help
Old Mar 31, 2018 | 10:14 AM
StanVanDam's Avatar
StanVanDam
There seems to be several replies in this thread that don't appear anymore. Relating to the part number you posted, 17630-16040, have you watched this video?
Deegee
May 9, 2018 02:29 PM
eliteskill
Jul 9, 2011 11:22 PM
Deceptik1
Nov 21, 2007 06:25 PM
