Headlight not projecting beam equally
Old Feb 15, 2018 | 05:09 PM
foodbear's Avatar
foodbear
Default Headlight not projecting beam equally
Hello everyone, my first post so I hope you can help. My 2004 LS 430 has only 39,000 original miles in great shape BUT for a recent issue with my headlights. I noticed that the headlight beams on both sides are not projecting as far as they used to and at a much shorter range than normal. Nothing appears damaged to either headlights, etc., no fogging, no cracks. I would like to know if anyone else has ever experienced this problem with a Lexus, and if so, what might be the problem. Thank you.
Old Feb 15, 2018 | 05:32 PM
rkw77080's Avatar
rkw77080
Please have a look at the link below for instructions to adjust the head lights...
https://www.clublexus.com/forums/ls-...eup-w-pix.html
Old Feb 15, 2018 | 07:53 PM
05ls430518's Avatar
05ls430518
what color is the actual light they could be hid bulbs thst are on there way out the door
Old Feb 15, 2018 | 08:14 PM
RushNatU's Avatar
RushNatU
Sounds like the headlight level sensor is either siezed or needs adjusted.
https://www.clublexus.com/forums/ls-...sue-input.html
Old Feb 16, 2018 | 03:27 AM
rkw77080's Avatar
rkw77080
Good point... If the two head lights put out different amount of light (but are aimed properly), then the dimmer one is on its way out. Always replace both to ensure proper matching (brightness, color, intensity, etc.) Here is a link to a DIY head light replacement:
https://www.clublexus.com/forums/ls-...placement.html
Old Feb 16, 2018 | 09:20 AM
afgdelmar's Avatar
afgdelmar
The lights seem to be a normal white light color -
wopdud
Mar 7, 2019 02:10 PM
tangcindz
Dec 14, 2016 05:34 AM
solefresh8
Mar 2, 2010 08:16 PM
inspector1
Feb 22, 2006 09:38 PM
lex_ga
Feb 11, 2003 09:47 PM
