2002 LS 430 - Tilt/Telescope Steering Wheel
Old Dec 11, 2017 | 02:02 PM
regulator8's Avatar
regulator8
Default 2002 LS 430 - Tilt/Telescope Steering Wheel
My tilt/telescope steering wheel does not telescope. Is it worth trying to repair or do I take it to a dealer?
Old Dec 11, 2017 | 02:25 PM
rkw77080's Avatar
rkw77080
Check out the link below for detail discussions.
https://www.clublexus.com/forums/ls-...-write-up.html
Personally, I would not try to "repair" the motor, instead, just buy and install a new one.
Old Dec 11, 2017 | 02:28 PM
bradland's Avatar
bradland
The telescoping bushing (4576860011) is known to wear out but is very inexpensive from the dealer. Should be under $5.
Here's a great post on the issue https://www.clublexus.com/forums/ls-...-write-up.html
I'd try replacing the bushing and during the process you should be able to tell if the motor has failed or not.
Old Dec 11, 2017 | 04:04 PM
regulator8's Avatar
regulator8
Post 2002 LS 430 Telescoping Steering Wheel Problem
Thanks, rkw, for the link. I just discovered I should have said my steering wheel won't "Tilt" and like a bonehead I said the opposite. I searched the forum and found a couple of links, with pictures. If the fuse is okay I think for now I will adjust the steering wheel to my preferred location and leave it at that.
Thanks again and I'm sorry for the confusion I caused.
Old Dec 11, 2017 | 04:09 PM
regulator8's Avatar
regulator8
Post Tilt/Telescope Problem
Thanks for your reply bradland. I discovered I screwed up when I posted and should have said my steering won't "Tilt." For some unknown reason I said the opposite. I found a couple of links on tilting problems and I will check them out tomorrow when I have more time.
Thanks again for you timely post.
Old Dec 16, 2017 | 05:39 AM
donpow75's Avatar
donpow75
Regulator8 can you post links to the threads you found on the issue. I just picked up an '02 LS430 and I have the exact same issue, it won't tilt but it will telescope. Thanks
Old Dec 16, 2017 | 06:15 AM
rkw77080's Avatar
rkw77080
Try the link below (start with Post #13)...
https://www.clublexus.com/forums/ls-...placement.html
jknoxxx
Apr 8, 2022 01:50 PM
shwhitley
Nov 22, 2018 08:43 AM
okonime66
Apr 23, 2014 06:31 PM
BOOGEYMAN4
Aug 4, 2011 01:14 PM
dleadlexus
Jan 12, 2010 10:52 PM
